Old 08-07-2010, 02:25 AM   #2761
Originally Posted by gfilos View Post
if installing the long rods you can get them more than 68mm something between 70~72mm when full extended. the length of the body
including the plastic ball joint at top is 39.2mm
what about from hole to hole?
TEAM DURANGO CARBON DEX210 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
TEAM DURANGO CARBON DEX410 - POWERED BY TEKIN RS PRO/REEDY SONIC 17.5
TEAM ASSOCIATED B5 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
LiL_JaSoN is offline   Reply With Quote
Old 08-07-2010, 07:40 AM   #2762
Scott Kimbrow's Avatar
Originally Posted by Team Kamikaze View Post
You don't use a sway bar on the DLS!
I did not use a rear sway bar, however, Paolo and Salven did. The car with the DLS has more rear grip, which I like. Those guys wanted more steering so they added the rear swaybar.
Serpent / Serpent America / Novarossi / Spektrum / Xceed Tires / Tornado Fuel / Empire Racing / Protoform / Thunder Power / Avid Bearings / A-main Hobbies / Dynamite
Scott Kimbrow is offline   Reply With Quote
Old 08-07-2010, 07:45 AM   #2763
Originally Posted by stefan View Post
Scott, how difficult is it to get the DLS system adjusted correctly and how hard is it to keep it that way?
I did not personally install it, my mechanic at the Worlds, Jim Adkins did, but it was easy to get setup and install, and we never had to readjust it.
Old 08-07-2010, 08:45 AM   #2764
quietstorm76's Avatar
Hey Stefan, There is a set measurement for the long rods. Between the ball cup I think it's 47.7, I will double check. No adjustments needed after that. I ran without the sway bar most of the time. I did try it with the sway bar and gained more steering. It changes the car but only took half a tank to adjust to it. After that it felt normal.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 08-07-2010, 08:54 AM   #2765
lil-bump's Avatar
Trader Rating: 83 (100%+)
Hate to change the subject. I've been looking at the serpent clutch on the 733 and I've come to the conclusion; that on the 733 clutch you can not properly measure the clutch shoe gap with a Hudy or EDS clutch gauge/tool. The thrust bearing is recessed inside the clutch bell. Am i correct in this statement.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 08-07-2010, 09:10 AM   #2766
DS Motorsport's Avatar
Originally Posted by lil-bump View Post
Hate to change the subject. I been looking at the serpent clutch on the 733 and I've come to the conclusion; that on the 733 clutch you can not properly measure the clutch shoe gap with a Hudy or EDS clutch gauge/tool. The thrust bearing is recessed inside the clutch bell. Am i correct in this statement.
Pass you soon...
Remove the first gear pinion, then you're able to use the Hudy tool.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 08-07-2010, 09:29 AM   #2767
Pattojnr's Avatar
Trader Rating: 19 (100%+)
still wont help, as the pinion is just about flush with the end of the bell thread.
Sam had a good tool before to set clutch gap.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 08-07-2010, 09:49 AM   #2768
I've set the WC clutch hundreds of times in this way with the Hudy tool.
P1-RC.com
Old 08-07-2010, 10:23 AM   #2769
Pattojnr's Avatar
maybe its just the 8th thats flush, when your in a hurry to set your clutch for a Main and dont have much time, the Tool Sam at Kamikaze has is the quickest option, and who wants to be taking the 1st pinion off all the time Specially when your rushed. But it may be possible with the WC tourer clutch to do it that way. Sorry DS.
Serpent - Walter RC
Old 08-07-2010, 11:07 AM   #2770
lil-bump's Avatar
I take it your talking about Sam @ Kamekaze. What was the name of the tool? Is it the caliper gauge?
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 08-07-2010, 11:13 AM   #2771
Pattojnr's Avatar
I take it your talking about Sam @ Kamekaze. What was the name of tool?
Pass you soon...
http://www.kamikazetoysandhobbies.co...php?prod=TTCT1
Serpent - Walter RC
Old 08-07-2010, 11:45 AM   #2772
gfilos's Avatar
From end to end default by manual is 68mm, however
installing long rods can help you to achieve 70-72mm. So, the distances in
your drawing are 68mm (70-72mm using long rods) and 39.2mm. Hole to hole
i dont know maybe 3-4mm less overall.
Serpent 720 09 mega zx 12 dsII+, Serpent 733 nova 353 tuned/sirio XXXV
Futaba, Graupner, Hudy, RB fuel
gfilos is offline   Reply With Quote
Old 08-07-2010, 12:37 PM   #2773
Roelof's Avatar
Send a message via ICQ to Roelof
A next step with that much grip could be a rear solid axle making the car more like a 1/8 car and with less weight in the drivetrain also better accelerating.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 08-07-2010, 02:28 PM   #2774
YR4Dude's Avatar
Trader Rating: 44 (100%+)
...The car with the DLS has more rear grip, which I like...
Would this enable you to run a harder shore in the rear to help improve tire wear and yet still get good grip?
YR4Dude is offline   Reply With Quote
Old 08-07-2010, 03:34 PM   #2775
captian's Avatar
what tire shore was run front and back
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
