Serpent 733 1/10 200mm touring
#2536
#2538
need a setup for 733 for the byrons race in joliet IL.
#2540
SERPENT 733 - What a car!
3rd race with it, and loving it more and more, I have a few things to try for the next race which I am sure will make it faster.
A couple of interesting things I tried over the weekend:
2 bevel diff - felt much better, alot smoother, plus the added bonus of saving on rotating mass - worked perfectly over 3 days of hard racing.
Yellow Clutch shoe - too agressive for my liking regardless of how low the spring was set.
M Plastics - massive grip difference over H, very durable and fit better.
DJ's shaved rear anti-roll bar trick - calmed the rear end nicely.
Has anyone tried the xceed diffs yet? I hear some of the other brands are having reliability problems with the composite diffs??
#2541
Serpent America Attending this event @ Controlfreakz....... You can't miss this race!!
#2542
just picked up my used 733. it looks great. I wonder does parts from my 710 fit my 733?
Can't race to get it on the track.
#2546
front belt
Hey guy's,
Ran my 733 for the first time on the weekend and what a great car. I done 2 practise sessions plus 6 qualifier heats and a 10min final. I'm stripping the car at the moment and have noticed that the front belt is partially stripped and the small pulley on the small layshaft is destroyed. i noticed that the belt seems to be running on the left hand side of the diff and layshaft pulleys very hard, i cant see anything that is forcing it over to this side of the pulleys. Where is everyone elses belt running in the centre or to one side or has anyone else had any of these issues at all.
thanks in advance.
thanks in advance.
#2547
Hey guy's,
thanks in advance.
thanks in advance.
#2548
Diffs
What about diffs anyone had issues with them leaking at all ???? are you using sealant at all etc
And yes i use a shorter screw on one side.
Thanks again....
Still wrapped with the car even with these little teething issues
Thanks again....
#2549
...a little leakage in one of my diffs as well...brand new.
I`m trying to find the Orange Serpent colour (limited stock of paint in the shops here in Norway).
I`v bought 5 different ones, and they all are awful.
Can anybody guide me to the correct colour.....
Best Regards
Noooob
Best Regards
Noooob
#2550
when assembling them, diff fluid gets in the tubes where the screws go, and fills them up, and when the cases compress, if you have the pulley on it, a fair bit of diff fluid gets caught up. i really think its a weapage of the diff fluid coming out around the screws, and leaks down to the joint if left sitting for a while in one spot. i have used sealant on the diff o ring, and i try to clean out the pulley screw side of oil, as i think it compresses so much and stresses the plastic tubes as well when fitting the remaining screws for the pulley. Just my thaughts , regards, Patto.
