Old 06-08-2010, 08:30 PM   #2491
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Julius View Post
You should not use or need that much steering throw. The steering blocks can turn more than the cvd's will allow, so just adjust travel to keep the joints from binding.
sometimes the grub screw comes out and starts locking things up, i always remove the set screw in the CV.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 06-08-2010, 08:52 PM   #2492
wee
tks patto and julius for yr advise. but i never install screw at cvd.
well i hv check every thing. seem like all of them r in order
for the steering throw, my turning radius, i adj. until there is no binding on the servo (70% to 80%). still cant figure out the problems..
it doesnt matter whether i use solid, diff or spoon right?
should i change the cvd or front knuckle
SERPENT S733 , S966 , S811 , S400 , S411 TE & S747 SOON.......
POWERED BY NOVAROSSI ( GP )
POWERED BY HOBBY WING V3, SPEED PASSION AND LRP (EP)
wee is offline   Reply With Quote
Old 06-08-2010, 09:29 PM   #2493
nitrodude's Avatar
Julius told you what the problem is, your steering trow is too much, set your enpoints for less trow so it won't bind up the cvs when you turn.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 06-08-2010, 10:20 PM   #2494
Pattojnr's Avatar
well i setup my steering the same way, and funny enough i dont have this problem . remember this is happening after an accident, i would gather something is bent. swap cv's left to right and see if the problem changes sides, i would imagine a bent shaft ?
Serpent - Walter RC
Old 06-09-2010, 03:30 AM   #2495
wee
Default steering problems
well guys tks for great help and advise,
will try to change cvd and check other thing which might cause it.
tks again it have being great help
Old 06-09-2010, 10:44 AM   #2496
ast
Default wet practice
practice in the wet yesterday
Serpent 733 , Sirio XXXV , Savox , Spektrum , Li-Fe
ast is offline   Reply With Quote
Old 06-09-2010, 10:53 AM   #2497
wee
Default cvd joint
well guys,
i found out what cause the knock when i turn to max for
the steering is not cause by the screw or bend shaft, is the wear and
tear on the shaft itself. when we turn left and right ,the cvd pin steel
wear off the shaft slot where the pin sit.... so when i change new shaft
where ever i turn no more knock.
just to share this experience with all
good luck to all on race
make sure all of you need to check this in future..
thks again for guideline
Old 06-09-2010, 09:55 PM   #2498
advfuel's Avatar
Trader Rating: 29 (100%+)
Well had my 1st run with the 733 on the weekand and the 1st for over 2 years in a nitro tourer.
My 1st thoughts was how easy is this to work on. The car was on rails all weekand. Had a small issue with my tire choice at the start of the weekand but with a change to the Exceed tires, all was well.
I would like to thank Patto for suppling the new 733 car and setting it up for me. Also you knowledge on the Serpent was a welcome releif. Having you race at our local track to ask questions and help with parts and tires sure made my weekand easier.
I quilified 5th and finisehed 5th in the main sure made for a great weekands racing.
Heres a pic
advfuel is offline   Reply With Quote
Old 06-09-2010, 10:07 PM   #2499
jca2000au's Avatar
Trader Rating: 9 (91%+)
Originally Posted by wee View Post
well guys,
You dont need to use the grab screw to tight pin on GP car, as bearing with cover each end of the pin. Pin will wear and created flat spot. I never use grab screw on MTX4, NT1, RRR and now 733.
jca2000au is offline   Reply With Quote
Old 06-10-2010, 01:36 AM   #2500
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Nice rain pics
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 06-10-2010, 04:33 AM   #2501
how did your car handle in the rain?
i tried running in rain once and it was very slippery... drifted every corner
TEAM DURANGO CARBON DEX210 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
TEAM DURANGO CARBON DEX410 - POWERED BY TEKIN RS PRO/REEDY SONIC 17.5
TEAM ASSOCIATED B5 - POWERED BY TEKIN RS GEN2/TEKIN GEN2 17.5
LiL_JaSoN is offline   Reply With Quote
Old 06-10-2010, 11:32 AM   #2502
ast
it was good , you just have to be carefull with the throttle , using these tyres http://demonpowerproducts.co.uk/prod...oducts_id=3022 Schumacher XG-WET BRCA 2008 Wet Tyre
Old 06-13-2010, 08:18 PM   #2503
gearhead_22's Avatar
Send a message via AIM to gearhead_22
Default better late than never
I got my 733 today and man what a diffence from my 720 very pleased.
serpent sdx4 srx2 977WC-novarossi-748TQ
serpent S120 LTR-S411
serpent America/Ashford Hobby/skyrocket racing
Juwan Hunter
gearhead_22 is offline   Reply With Quote
Old 06-14-2010, 11:34 AM   #2504
Default concerned
Greetings fellow Serpent enthusiasts:
was hoping to get some feedback on an issue I currently have with the "EEL"
to date I have burned through 4 lower "right" wishbones (this season alone). The last one was an "H". Now im not the best driver on the planet but I dont think im abusing the boards more than the Kyosho or Mugen guys. Letís just say that 2 of the 4 impact occurrences were light and the final two were negligible taps. To me this signifies that I have located a weak spot in the material or design of this particular component. In every case I have cracked the pivot ball enclosure at the end of the wishbone. Just cracked, nothing more. The actual pivot ball ends up pulling out on impact.
or perhaps its something else entirely...
let me ask you guys how ya feel about NitroSpay. I have been using it religiously for years (well derivatives of Nitro Spray for that matter). I understand that over time it makes certain plastics brittle. I was thinking that perhaps the material Serpent uses is a little more prone to instability when coupled with whatever chemical reaction this "Nitro Spay" induces?
or
that my level of suck just far exceeds this reader base?
Its quite possible a lighter, better handling car was not what I should have purchased when deciding to get back in this hobby. It may turn out that the Tamiya RC tank would have been the better fit for my driving style. At least I could shoot a plastic dart at other drivers distracting them as I turtle by for the win...
Thanks for any assistance you can provide.
Kampfer
kampfer2010 is offline   Reply With Quote
Old 06-14-2010, 11:39 AM   #2505
nitrodude's Avatar
IF you hit hard enough, something will break, theres no way around it. I have had hits where I was sure my car should be broken, yet it kept going. I have hits that didnt seem that hard to me, yet the car broke, and that goes for any brand. Just keep it in the middle, hard I know.
Steven Muller
Ronin Speed Parts
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
