Old 05-24-2010, 08:10 PM   #2431
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Yes they are zero degree
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 05-24-2010, 08:13 PM   #2432
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
is there a way to tell which ones you got?
yokomo yz-2
Ultraspeed84 is offline   Reply With Quote
Old 05-24-2010, 08:25 PM   #2433
"Smiley"'s Avatar
Trader Rating: 166 (98%+)
Hey Robert,
Great job this past weekend. Your car looked very good.
Vision Racing Products | Team Associated | AKA | Tekin | Sanwa | VP Powermaster Fuel | RC Concepts Engines | MIP | Avid | Boom RC Graphics | Paint By: "Smiley"
Vision Racing Products (VRP)- www.visionracingproducts.com
"Smiley" is offline   Reply With Quote
Old 05-24-2010, 09:01 PM   #2434
Rock Racing's Avatar
Trader Rating: 38 (100%+)
Originally Posted by "Smiley" View Post
Hey Robert,
Yeah it got alot better with the changes i made and the new motor and two speed finally came in....oh and thanks for the sick paint work Smiley, ive never seen a body turn out so good for a 24 hour turn around! i hope someone got some action shots.....here's a pic before stickers.....please ignore the ugly guy in the pic (me)...focus only on the paint
P.S dont forget that i want you to do all my bodies including the one that jeremy's going to give you later this week. Keep up the good work!
Serpent 733 1/10 200mm touring-cimg0657.jpg
Rock Racing is offline   Reply With Quote
Old 05-26-2010, 09:23 AM   #2435
Gonzo RR's Avatar
Hey so yesterday I finished installing an RB Concept R3 That was modded by Rick Brake himself it now has 5 PORTS and should be freaky fast... We shall see!
My question is do you guys running the 733 usually change anything on your setup when you run an engine that you know will run faster??? Since the car will get from corner to corner quicker?
Xray NT1 '08 /'09 EC LRP12R / Serpent 720 '08 RB Concept V12, R3 RB mods, V12 Rody, Matrix RW / Serpent 733, 733TE RB T9 / EA RC8T OS .21 Vspec speed tuned / Kyosho Inferno GT, GT2 / EA SC10 / Serpent Cobra GT coming soon!
Gonzo RR is offline   Reply With Quote
Old 05-26-2010, 11:29 AM   #2436
quietstorm76's Avatar
I wouldn't change anything until you put it on the track. Run it with your normal setup so you can see if it's faster.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 05-26-2010, 02:23 PM   #2437
Team Kamikaze's Avatar
Default Available!
Xceed composite gear-sets for 733 geardiffs.
http://kamikazercracing.com/proddeta...prod=XCE108248
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 05-26-2010, 03:24 PM   #2438
"Smiley"'s Avatar
Gotcha Robert, !
Old 05-27-2010, 03:45 AM   #2439
Default Lube for one way bearing?
Originally Posted by M7H View Post
So don't forget to lube it before first usage...
Isn't any form of grease actually to "sticky" for the needles?
Or is the grease you are talking about more a sort of an oil?
And doesn't the one way lube work good enough?, or do you need to relube it to often then.
I know the one way lube works perfect one the "older" type of one ways....
Can I use the diff oil to lube the one way bearing? If so, the 30k, 50k, or something else? Do I generally want a grease or thin oil on the one way bearing?
Serpent fan
Serpent fan is offline   Reply With Quote
Old 05-27-2010, 03:49 AM   #2440
M7H
M7H's Avatar
Serpent fan
I use oneway lube, but according to DJ, the newer one way bearings have a tighter fit. I have 1 new bearing in my box, but not used it yet, so I can not comment on that....
http://www.rctech.net/forum/6349568-post1169.html
Serpent
M7H is offline   Reply With Quote
Old 05-27-2010, 04:30 AM   #2441
Default One Way bearing lube
I have the newer one with the tight fit.
If I can use Diff oil, which one should I use? The thickest one, or the thinnest one?
Old 05-27-2010, 04:40 AM   #2442
Pattojnr's Avatar
Trader Rating: 19 (100%+)
try the black grease, or as i use, Ball diff grease. the diff oil may just fly straight out.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 05-27-2010, 05:29 AM   #2443
I don't know of any of those. The black grease, is that something that came with the kit?
So basically I want a rather thick grease, so that it won't get flung straight out?
Can I take some grease from a bucket at work? It's the kind of grease that does not run, it has a pretty high viscosity.
Old 05-27-2010, 06:20 AM   #2444
Pattojnr's Avatar
the black grease i believe is the Xceed Black grease. i wouldnt use a general purpose Automotive grease, it may do more damage than good. some rubbers and plastics dont like it, maybe the plastic retainer inside may disolve over some time. Ball diff grease can be baught at most Hobby shops i would believe. it is used in EP ball diffs.
Serpent - Walter RC
Old 05-27-2010, 06:51 AM   #2445
Ah, ok. Thanks for you help
Will this one do for example?
http://www.globy.no/page/products/142224/
Do I have to take the "gearbox" apart to put the grease on? Where exactly do I put the grease? (I sound like a newbie because I am one )
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
