Old 05-20-2010, 10:16 PM   #2401
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Novarossi View Post
Anyone know the weight difference between the Stock 2 Speed shaft and the CSO Lightweight shaft?
http://www.rctech.net/forum/7038406-post1959.html
looky looky
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 05-20-2010, 10:23 PM   #2402
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Originally Posted by Pattojnr View Post
Cool, thanks Patto + Ericroc.
How does the CSO disc compare to the standard disc?
I found the standard brakes to be very good, with no fading in long finals, but if the CSO version saves additional weight and performances as good if not better then the standard disc, I might go for both and save 9grams.
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is online now   Reply With Quote
Old 05-20-2010, 10:30 PM   #2403
Pattojnr's Avatar
i havent had issues with the cso brake disc. but seems only one set of holes fit the brake pulley freely, but id like the new Xceed one when Walters has them in stock, if not already. i want my car fitted out with orange and green stuff
Serpent - Walter RC
Old 05-20-2010, 11:21 PM   #2404
jca2000au's Avatar
Trader Rating: 9 (91%+)
Mr. 19.00sec get this http://www.xceedrc.com/product/103024 10g !
jca2000au is offline   Reply With Quote
Old 05-21-2010, 10:39 AM   #2405
YR4Dude's Avatar
Trader Rating: 44 (100%+)
The CSO brake is more consistent than the stock brake. I also like the fact that I don't have to mess with three pieces instead of the one with the CSO. Had the Xceed been out earlier, I would have gotten the Xceed brake because of the "venturi" design but I doubt if there is any difference in performance between the CSO or Xceed, both are better than stock. Its just a matter of choice.
YR4Dude is offline   Reply With Quote
Old 05-21-2010, 06:31 PM   #2406
chromie's Avatar
Hey,
I would like to know if I can just use the pre body mount holes on the chevy body for my 733. Will it line up properly?
chromie is offline   Reply With Quote
Old 05-21-2010, 07:56 PM   #2407
Team Kamikaze's Avatar
Originally Posted by chromie View Post
Hey,
Marc, Try lining it up the body first on the car while it is still clear.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 05-21-2010, 08:17 PM   #2408
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
No it's a lil off just mount it center with the front wheels
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 05-21-2010, 09:50 PM   #2409
YR4Dude's Avatar
Hey,
I kinda does. However I checked still just to be sure. Those pre body holes are nice as a guide but I still would not trust them 100%.
Old 05-21-2010, 10:34 PM   #2410
chromie's Avatar
Alright thanks guys, just wanted to know if I could use the pre holes because I hate doing body work. Could never get a good cut out body.
Originally Posted by Team Kamikaze View Post
Nik, Try lining it up the body first on the car while it is still clear.
I'm not Nik. I'm his brother Marc
Old 05-21-2010, 10:51 PM   #2411
Sorry, to call you Nik, after all you both look alike
Old 05-21-2010, 11:26 PM   #2412
jca2000au's Avatar
Has anyone try new XCEED composite gear diff?
Old 05-22-2010, 07:46 AM   #2413
chromie's Avatar
Heh
Old 05-22-2010, 10:25 AM   #2414
quietstorm76's Avatar
Hey,
They will shift the body off center, so I wouldn't trust them. It's close though.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 05-22-2010, 07:41 PM   #2415
Michael_T's Avatar
Originally Posted by shamu View Post
The NT1 pivot balls are a direct fit
Sorry to ask again, but are you sure they are a direct fit?
The NT1 balls are 8.4mm and the 733 balls are 8.5mm?
And do you use the steel balls (silver colour) or the hard coated balls (black colour)?
Thanks.
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
