Old 05-11-2010, 02:04 PM   #2356
Joey4875's Avatar
Originally Posted by dj apolaro View Post
Flat!
And the flat spot should be in the vertical position when on the car?
Xray,Hudy,RC America
Joey4875 is offline   Reply With Quote
Old 05-11-2010, 02:23 PM   #2357
dj apolaro's Avatar
The picture in post 2348 is as it would look in the car from the top.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 05-11-2010, 04:12 PM   #2358
Joey4875's Avatar
Thanks grind alittle off both sides
Old 05-13-2010, 06:46 AM   #2359
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Heard a rumour that the driver who TQ'd this years Winternats will now be racing the 733 at the Worlds
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 05-13-2010, 08:10 AM   #2360
Team Kamikaze's Avatar
It's only a "RUMOR"
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 05-13-2010, 03:46 PM   #2361
Ericroc's Avatar
Hi guys,
today i am so upset about the quality of the 733. From the start, i had to replace some parts of the car with some olé coming from my old 720. All the bearings had to be replace after the first run!
The pivot bowl in the shock absorber ad to be replace with the one from the 720 cause impossible to fix it.
The alu pivot bowl in thé arm break today with no reson????!
And a lot of bad things but i don't know all the english names or don't know if it's correct but thé big pine nut on the two speed shaft, i had to replace it six time!
I think i Will put all the car in the garbage and move to another brand or stop rc!
Serpent, it's just a shame, no other word to describe that!
La révolution n'aurait pas eut lieue si ils ne l'avaient pas faite!
Ericroc is offline   Reply With Quote
Old 05-13-2010, 03:57 PM   #2362
Rock Racing's Avatar
Trader Rating: 38 (100%+)
Dibbs! Ill be your garbage sell it to me cheap! I love mine with no problems. This car is winning everywhere.
Rock Racing is offline   Reply With Quote
Old 05-13-2010, 04:06 PM   #2363
Race # 10 -- .12 SEDAN - A Main -- (GREEN)
Qual Qual time name car# freq id p txid
1 24/5:08.86 CHRIS TOSOLINI * 1 Spektrum 80 3582314
2 24/5:10.32 PAOLO MORGANTI * 2 Spektrum 89 7920292
3 24/5:11.23 PAUL LEMIUEX * 3 Spektrum 66 7037997
4 24/5:11.96 MIKE SWAUGER * 4 69 24 4860087
5 23/4:59.45 RALPH BURCH * 5 Spektrum 65 2141172
6 23/5:02.73 DJ APOLARO * 6 Spektrum 87 9543468
7 23/5:03.30 CHRIS LEFEBVRE * 7 Spektrum 60 2781941
8 23/5:10.47 SCOTT RISTER 8 Spektrum 8 6957301
I would be surpised !!!!!!!!!!!
Mike 78 is offline   Reply With Quote
Old 05-15-2010, 03:25 AM   #2364
tcmodels's Avatar
funny Chris to 733
www.tcmodels.net - online hobby shop
tcmodels is offline   Reply With Quote
Old 05-15-2010, 06:05 AM   #2365
Joey4875's Avatar
He works at serpent america now I know that for a fact he been racing the 811 off road buggy that serpent just came out with. And thats straight from the man himself.
Old 05-15-2010, 03:44 PM   #2366
quietstorm76's Avatar
Originally Posted by Ericroc View Post
Hi guys,
Really sorry to hear you are having those problems. I've had mine for about a year now and the only problem I had was the original fuel tank. It's a great car but sorry for your experience.
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 05-15-2010, 04:01 PM   #2367
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Hi guys,
Was it breakage from crashing or did it just break for no reason? Also on the two speed, did you have it mounted correctly? Your problem with that could be that you are doing it wrong. I never had any problems with my two speed shaft. As for bearings, did you lube them before running it? If you didn't then that is why they burn up. Bearing replacement is common for RC nitro cars, its all part of maintenance.
The only reason to give up on a car is:
  1. It doesn't handle no matter what you do to it.
  2. It is difficult to fix/ work on.
  3. It has no parts support.
The 733 does not have any of those above problems. However if it is not as durable as you "expect" it be, then you should be shopping for a tank and not a race car.
YR4Dude is offline   Reply With Quote
Old 05-16-2010, 01:40 AM   #2368
NiTrO BoOsTeR's Avatar
hey guys just started the engine in my 733 and had a bit of a put around, could someone tell me the fix for the leaking diffs.
other than that i think the car is superb, although a little rust is starting to happen on the screws and 2speed shaft but caught it in time to put some oil on them.
thanks guys
Mitch
Serpent 733 - RB T10rc - Ko Helios EX-10
Serpent 733 - Novarossi 3SCT Tuned
============== SERPENT the only way ============
==== Pro Buggy Rc, Pitsworth - for all my RC needs =====
NiTrO BoOsTeR is offline   Reply With Quote
Old 05-16-2010, 03:01 AM   #2369
I read about some issuse around leaking diff and some have damage the diff housing when they thighten the srews. So the first time i assamble the diffs i were very soft when i thighten the srews. My diffs were leaking a litle. A litle i mean i could see some oil after some days when the car was standing on the table. I thighten then the screws a litle more and they where good. After this i have had no issue. When i change oil in the diff ill be wery carefull to thighten the screws on cross and do it a litle at the time as long as i whipe it clean for ecceding oil so i can se that to o-ring is staying on its place. the screws has to be thighten firm but of course not to much. Thighten them a litle at the time on cross and you can feel when they are thighten enough. Never had a leaking diff sinse.
speikey is offline   Reply With Quote
Old 05-16-2010, 03:07 AM   #2370
Gergely's Avatar
Hello Mitch,
Make sure to fill up diff like the picture in the manual and also to use the big o-ring. Double check that you use the correct length of screws. You can also put some sealant on the o-ring.
thanks guys
Mitch
Gergely is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
