Old 05-07-2010, 11:19 PM   #2341
speedoutlaw's Avatar
Default 733/biggie
ohla mr.rocha how r u amigo. i was glad i used the losi lube on the thrust bearing did not have none but i did use and reccomend the xceed lube for the one-way been using it for the last year and a half and is awesome. no problems. i also tried the rear arm link set-up that paolo talked about and man does work. i started where he described and brought down to 3mm. rest was similar to DJ'S or almost close to. car was sleek and fast and yes serpent cars were the fastest out there!!!!!!!!!!!!!!!GO 73333333333333333 SEE YA AT THE WORLDS!!!!!!!!!!!!!!!!!!!
WHO WANTS MILK GOT SNAKE!!!!!!!!!!!
___________________________________________________________________________
Sponsors;* TEAM SERPENT AMERICA* *733 *---*o.s.engines - * FUTABA RADIOS*--*TWISTER TIRES*---*MAXY'S PRO RACING FUELS*-- ---*TEAM SPIDER*--
speedoutlaw is offline   Reply With Quote
Old 05-09-2010, 06:14 AM   #2342
Hi , I want to buy a 733. I have a question for my ordering.
Inside the box with all the parts ,wich shocks are inside , the colors of springs , so I can order the other color springs directly in one time.
Univerziuz is offline   Reply With Quote
Old 05-09-2010, 06:53 AM   #2343
Pattojnr's Avatar
Trader Rating: 19 (100%+)
just get the short and long spring kits. this will cover it all, also look at the front sway bar set, and the 2.3 rear sway bar. everything else from the kit is enough. if you like the front solid axle, then go for that as well.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 05-10-2010, 03:44 AM   #2344
Hi DJ Apolaro.
I have sitting and made your setup from Sour Grapes /Ft Myers on my 733, but i cant figure out how you can have any ridehigt whit your front downstop at 4mm. Are this correct or did you meen -4mm ?
Speikey
speikey is offline   Reply With Quote
Old 05-10-2010, 03:57 AM   #2345
Alex Siddique's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Alex Siddique
Originally Posted by speikey View Post
Hi DJ Apolaro.
Speikey
time u had some sleep and read again . front droop is .5
No Fucker's Taking my money O/s OR local :) :)
Alex Siddique is offline   Reply With Quote
Old 05-10-2010, 04:17 AM   #2346
Your right. I will aim for the bed at once.
Speikey
Old 05-10-2010, 10:33 AM   #2347
dj apolaro's Avatar
4 is for the rear and .5 for the front.
Thanks guys for looking out. Sorry it took so long to reply, but I was getting some sleep actually.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 05-10-2010, 10:37 AM   #2348
dj apolaro's Avatar
Someone asked me for this so here is a pic of the rear sway bar.
DJ
Serpent 733 1/10 200mm touring-rear-sway-bar-001.jpg
Old 05-10-2010, 04:54 PM   #2349
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Hey DJ how's it going, on ur set up sheet it states 0 under the rear link is that correct or did u get the track record with 5mm under the link? Thanx
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 05-10-2010, 05:18 PM   #2350
dj apolaro's Avatar
Originally Posted by Serpent-Dan View Post
Hey DJ how's it going, on Ur set up sheet it states 0 under the rear link is that correct or did u get the track record with 5mm under the link? Thanx
I tried the shims once, however I stayed with no shims on the upright and the race that I set the record was with no shims. I only tried running shims in a practice once and liked it better without.
DJ Apolaro
Old 05-10-2010, 05:27 PM   #2351
Thanx DJ
Old 05-10-2010, 08:10 PM   #2352
Joey4875's Avatar
DJ
Are you rounding it or are you just grinding it flat to get the 1.1
Xray,Hudy,RC America
Joey4875 is offline   Reply With Quote
Old 05-10-2010, 09:53 PM   #2353
two stupid questions.
1. when dj talks about +0.5mm front and 4mm rear downstops, is this measured with the shocks and sway bars mounted? or do you remove them? the setup sheet shows these measurements with the shocks mounted
2. with the front and rear belt tensioner things on the diffs, do both left/right need to be symentrical? for example, do the left and right slots need to be the same (middle slot left/right or front slot left/right etc etc). can the left one be say in the first slot and the right one be in the middle slot to get optimal tension in the belt?
implusepro is offline   Reply With Quote
Old 05-10-2010, 10:10 PM   #2354
dj apolaro's Avatar
1. Yes, with everything removed
2. Both need to always be the same.
DJ Apolaro
Old 05-10-2010, 10:11 PM   #2355
dj apolaro's Avatar
Flat!
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
