Old 04-19-2010, 01:54 AM   #2191
Toaster's Avatar
Originally Posted by Alex Siddique View Post
mate the first race is always a good one its the second and 3rd etc when it gets hard lol . If you using spacers on the pulley holder the e clip will pop too. but your car did look very good on the track . As for me it feels like going backward the car seem to want a different setup week to week racing even on the same track .
Patience Alex it is good car, PB at Lilydale 2nd time out with a well run in RB T9
The high grip surfaces of NSW tracks it should be a weapon.
So far the best change I have made is the front diff.
Good Luck
Alex
Futuba 4PK, CAPRICORN C02 , TITAN TOOLS,MRCCR
Toaster is offline   Reply With Quote
Old 04-20-2010, 04:10 AM   #2192
Default Pins in CVD's and dogbones
The pins in my CVD's and dogbones are having flat edges after a couple of races. Do you guys replace the entire bones if this happens or is there a possibility to just replace the pin?
ma_RC_el is offline   Reply With Quote
Old 04-20-2010, 09:45 AM   #2193
nitrodude's Avatar
Are you putting any lube on the pins? Use either AE black grease, or whats better, Xceed Premium lube
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 04-20-2010, 10:51 AM   #2194
trickd122's Avatar
+1 however you can replace the pins. These CVDs are the strongest I have seen. I have yet to break one.
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 04-20-2010, 11:04 AM   #2195
nitrodude's Avatar
My rear CVDs are the ones that I used on the front of my S720 for a year, and they are still good, and never broke one.
Steven Muller
Ronin Speed Parts
Old 04-20-2010, 12:15 PM   #2196
What is the Serpent part # for the pins in the CVD's.
Thanks.
Kendall is offline   Reply With Quote
Old 04-20-2010, 02:02 PM   #2197
Team Kamikaze's Avatar
Thanks.
http://kamikazercracing.com/proddeta...=HUD106052-733
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 04-21-2010, 06:13 PM   #2198
RC MARKET's Avatar
CSO 3x10mm pin 10pcs $3 only !
RC MARKET is offline   Reply With Quote
Old 04-21-2010, 07:22 PM   #2199
Alex Siddique's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Alex Siddique
any one having issues with the diff plastic hollow pins snapping off ( where the screw go in )
No Fucker's Taking my money O/s OR local :) :)
Alex Siddique is offline   Reply With Quote
Old 04-21-2010, 08:04 PM   #2200
Pattojnr's Avatar
Trader Rating: 19 (100%+)
first batch i did. but new parts seem better. its a pain, but i think its sorted now.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 04-21-2010, 08:25 PM   #2201
must be the old batch then as i didnt have the problem with all the diff case but 2 new in packet both did the same .
Thanks pattojnr
Old 04-22-2010, 08:39 AM   #2202
nitrodude's Avatar
You have to take your time with the crews, if you try to go to fast the plastic heats up and they break.
Steven Muller
Ronin Speed Parts
Old 04-22-2010, 11:25 AM   #2203
YR4Dude's Avatar
Trader Rating: 44 (100%+)
You need to make sure to use the right screw.
There are two sets of self tapping screws that come with the diff. One set short and one set long. The difference is slight by about 2mm but it makes a big difference. When building the diff, use the SHORT screw. Although the longer one may seem to work, you might get away with one hole but you will eventually get one that will strip or break (diff half) which is what you have.
The longer screws are for mounting the diff pulley onto the diff. Even there I've had some issues. What I did instead is use the SHORT screws for both the diff half and the pulleys and that has been good for me so far.
YR4Dude is offline   Reply With Quote
Old 04-22-2010, 11:33 AM   #2204
SMcpot's Avatar
Trader Rating: 22 (100%+)
I've also had good luck using bicycle chain dry lube; doesn't attract dirt and everything I've used it on, onroad or offroad, seems to wear very well.
SMcpot is offline   Reply With Quote
Old 04-22-2010, 01:55 PM   #2205
Trader Rating: 31 (100%+)
Which lube are you using? I have used the White Lightening with good results.
Scott
1968 Camaro: 1:1, 5.3L LM7, Complete Restoration in Progress
SC10 Brushless
RC10B64 Club Racer
sdphilips is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
