Old 04-16-2010, 10:52 AM   #2176
Julius's Avatar
Originally Posted by captian View Post
so julius which ones do you recomend
I've been runnig 60k in fron and 50k in the rear. But I could imagine using up to 80k in the front when the traction is low to prevent too much loss of forward traction.
I've been playing around with the solid front with 40 to 50k in the rear and that works well too.
But the main thing with oil diffs is making sure they're full, and filled the same way each time or the comparison will never make sense!
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 04-16-2010, 12:13 PM   #2177
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Originally Posted by skidoos View Post
hey guys considering sellin my serpent 733, no place to run them here no more, ran it 4 times plus break in very slow on break in on clean parking lot, car has hitech digital servo on steering, futaba digital on throttle, how rb logics turbo pipe, comes with another rd logics brand new in box pipe, has to motors, orion crf.12 with 10 tanks on it including break in, also max power MF tuend motor with half a gallon which was in my 720, have extra brand new belts, brand new extra complete centex clutch and new tires and starter box, can sell as a rtr with futaba 3pk fast system, any serious enquires can email me at [email protected] or pm me here, luv the car , but no track here so i am off to offroad, if u have any doubts about me, u can look at my feedback on ebay, name is gonsledn , i sell only good stuff and clean
You need to post this in the "For Sale" forum. The pics you show can speak for themselves.
YR4Dude is offline   Reply With Quote
Old 04-17-2010, 07:34 AM   #2178
keavze's Avatar
Default tires
after about 15-20mins on track, my front and rear tires would endup the same size although i started out with a 2mm split. i noticed the tires surface of my fronts to be rough; however my rear tires surface is very smooth...using 37F and 40R.
is there something not right? what could've caused this?
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 04-17-2010, 09:14 AM   #2179
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
the front tires may just be to soft up front for the conditions. Does the car start to get tighter on u as u drive?
yokomo yz-2
Ultraspeed84 is offline   Reply With Quote
Old 04-17-2010, 08:44 PM   #2180
your rear tires will allways wear faster than the fronts your not doing anything wrong thats just how it is
Capricorn LAB C-01 / RBtj 10 / Spectrum DX3
Roadrash730 is offline   Reply With Quote
Old 04-17-2010, 10:23 PM   #2181
keavze's Avatar
ya i understand that the rears will wear faster than the fronts; the thing i'm cornered about is that the surface texture of the tires after running them.
fronts are rough and rears are very smooth, is it the rears are wheel-spinning too much causing them to be 'smoothen'?
Old 04-17-2010, 10:52 PM   #2182
Pattojnr's Avatar
Trader Rating: 19 (100%+)
when you see the foam all rough like it sounds, you will also see a ridge on the inside of the wheel, this means your tires are working, and suspension is possibly a little hard causing it to slip, you just dont know its happening, cause the tires take over. you can possibly go softer on springs on the front, and go to 40 all round. and then check the wear. also ackerman can cause the inside wheel to slip . this is like a feathering look on the foam. nothing is too wrong, just the tires are working overtime.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 04-18-2010, 12:06 AM   #2183
keavze's Avatar
thanks paul.
so the 'ideal' condition is to have the front tires smooth like my rears? but 'smooth' means tires not working?
instead of going from 37F 40R to 40 all round; will it be fine to go 37 all round? i cant find any 40F selling here at my lhs.
Old 04-18-2010, 01:59 AM   #2184
Pattojnr's Avatar
thanks paul.
was just something to try if you are concerned abuot the way the fronts are wearing. i get this when i run 35 rears. but i also push the car pretty hard with them on, cause i can (more rear grip) but there is a point where too soft will loose grip.
if your happy with the way the car is going, then the wear you are getting isnt really an issue. what would be an issue, if you needed more steering and its pushing.
Serpent - Walter RC
Old 04-18-2010, 03:34 AM   #2185
keavze's Avatar
Well, car handles quite alrite however if I push it really hard, it'll tend to push a little...any ideas that might help?
Old 04-18-2010, 04:07 AM   #2186
Pattojnr's Avatar
next step up in rear diff oil ? next up on rear spring ? try 42 rears.
spring is the easiest adjustment, try that first.
Serpent - Walter RC
Old 04-18-2010, 06:35 PM   #2187
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Anyone know what size the e-clip is that is used on the front middle shaft?
Is it 2.3? 4? 5? 7?
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 04-18-2010, 07:32 PM   #2188
Alex Siddique's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Alex Siddique
Is it 2.3? 4? 5? 7?
5mm , slightly squeeze em and pop them on .
No Fucker's Taking my money O/s OR local :) :)
Alex Siddique is offline   Reply With Quote
Old 04-18-2010, 10:43 PM   #2189
Michael_T's Avatar
Thanks Alex...
As you know, I had the front shaft e-clip pop off twice yesterday (once during practise, and during the A-main) which caused the inside pulley to fall off resulting in the belt falling off.
Otherwise, the car felt good and quick.
Old 04-18-2010, 11:42 PM   #2190
Thanks Alex...
mate the first race is always a good one its the second and 3rd etc when it gets hard lol . If you using spacers on the pulley holder the e clip will pop too. but your car did look very good on the track . As for me it feels like going backward the car seem to want a different setup week to week racing even on the same track .
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
