Old 04-09-2010, 10:12 PM   #2161
Trader Rating: 16 (100%+)
Originally Posted by ma_RC_el View Post
Shouldn't you use thinner oil in the rear diff, to get the rear more stable?
Thinner oil will make the rear tyre spin slower right ??
rossii is offline   Reply With Quote
Old 04-09-2010, 10:14 PM   #2162
Originally Posted by motojon View Post
u can try adjusting rear toe also
Ok,I just check my toe in, seems that I have too much toe,
instead of 1 degree I have it at 3. Now I will try back with 1 degree and see it helps or not...
Old 04-09-2010, 11:40 PM   #2163
gfilos's Avatar
Reducing toe-in will not help you, instead it will make it worse (increase off-throttle oversteer) . Leave it 3 degrees.
As for the diffs: try running thinner oil at the rear diff or/and thicker oil at the front diff. As a general rule, when the rear end
of the car doesnt have traction, we try to "borrow" some traction from the front (and vice versa).
Have a look on the setup book, it has nice info at the end with setup solutions to every problem (oversteer, understeer)
and when it appears (corner entry, middle, exit). If not available under 733 section, i am sure is available under 720 section. Make one change at a time and see how it works. Try first the changes with the highest priority (1,2,3, ..etc).
Good luck
gfilos is offline   Reply With Quote
Old 04-10-2010, 12:03 PM   #2164
nitrodude's Avatar
Originally Posted by rossii View Post
Hi to all 733 drivers,
I m currently facing my rear end kept throwing,
seems like less grip at the back..
Any one have idea how to solve such issues??
I have try using thicker diff oil and lower shore tyres
but stil not working..
Anyone got any idea???
Whats your setup?
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 04-10-2010, 09:15 PM   #2165
Thank you very much for the elboration.. Right now I have chane my chamber and toe in to 2.5 degree..
Diff oil I chanGe back to 30000cst. I also change droop from 3 to 2 due to my track which is quite bumpy.. I want to let the rear end to have more suspension travel under hard acceleration..
Good luck
Old 04-10-2010, 09:23 PM   #2166
Originally Posted by nitrodude View Post
Whats your setup?
My setup is 50000 rear diff oil,80000 for front diff.
Rear toe in at 2.5 degree, chamber at 2.5 degree for rear, droop at 3.
For front toe out is 2 degree,chamber at 2 degree, droop at 0.
All the chamber link and shock position I jus follow stock setup sheet for front and rear.
Above is my second session ,my first session is with 30000cst rear diff oil, with both sane setup, my car still fish tail during exit of corner, it get wilder when tyre wearS down. I suspect perhaps spring or droop may helps..
Old 04-11-2010, 12:15 AM   #2167
ast
change front toe out , and make it front toe in -1 degree , and also change rear diff oil to 30000cst
ast is offline   Reply With Quote
Old 04-11-2010, 02:38 AM   #2168
Thanks. I have already change to 30000 oil, I will adjust the toe out to 1 degree then and try it out.
Old 04-11-2010, 12:21 PM   #2169
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
id try 200,000 front and 30,000 rear that would prolly take care of alot and do the sway bar mod and u should be right there. atleast thats what im hoping on my car lol.
yokomo yz-2
Ultraspeed84 is offline   Reply With Quote
Old 04-11-2010, 07:43 PM   #2170
that is heavy diff oil for front man,, what do u mod on your rear sway bar ???
Old 04-11-2010, 10:57 PM   #2171
ast
you want at lest 100000k , but i would also go 200000k in front diff
Old 04-11-2010, 11:11 PM   #2172
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
I think the actual size of the Serpent diff needs to also be considered with diff weights.
The same diff oils that were considered 'normal' or 'heavy' in one brand would feel and act very differently in two different sized diffs.
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 04-12-2010, 03:15 AM   #2173
Julius's Avatar
That is true in part, but there is more difference caused by incomplete filling of diffs. I've seen many diffs which were not filled completely and thus felt "soft" for the oil that was supposedly inside.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 04-12-2010, 10:33 PM   #2174
captian's Avatar
so julius which ones do you recomend
serpent america * max power * beast mods *kopropo usa* protoform * team cmdi
captian is offline   Reply With Quote
Old 04-15-2010, 05:50 PM   #2175
hey guys considering sellin my serpent 733, no place to run them here no more, ran it 4 times plus break in very slow on break in on clean parking lot, car has hitech digital servo on steering, futaba digital on throttle, how rb logics turbo pipe, comes with another rd logics brand new in box pipe, has to motors, orion crf.12 with 10 tanks on it including break in, also max power MF tuend motor with half a gallon which was in my 720, have extra brand new belts, brand new extra complete centex clutch and new tires and starter box, can sell as a rtr with futaba 3pk fast system, any serious enquires can email me at [email protected] or pm me here, luv the car , but no track here so i am off to offroad, if u have any doubts about me, u can look at my feedback on ebay, name is gonsledn , i sell only good stuff and clean
skidoos is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
