Old 04-04-2010, 03:28 PM   #2146
Android's Avatar
So does the Nova Rossi 2652 pipe which is proven to fit and guaranteed to perform and cheaper than Max pipe!
Android is offline   Reply With Quote
Old 04-07-2010, 05:24 PM   #2147
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
Guys im wanting to know does this car have tons of steering and is it planted in the track? i need a setup for the car thats balanced and has good steering.. im running at toledo ohio next weekend any help would be great. And should i order the long springs and a one way that i can lock into a spool if need be? all the help would be great im about to order stuff...
yokomo yz-2
Ultraspeed84 is offline   Reply With Quote
Old 04-07-2010, 06:05 PM   #2148
quietstorm76's Avatar
Long springs for sure, Orange and red, if not full set. Try DJ's winternats 2010 or Salven's Houston setup from the link below. I like both of these.
http://www.serpent.com/product/804000/setups/
Team Shepherd USA:Nugget's Ranch Raceway
Primary Weapon: ?
Secondary Weapon: ?
Tires>>> I don't know yet
quietstorm76 is offline   Reply With Quote
Old 04-07-2010, 06:13 PM   #2149
nitrodude's Avatar
The car handles pretty good with the stock setup on most tracks, Toledo is a different ball game though. Last year at the Nats we had to do a lot of changes to the stock setup, I ended up running pink springs on all 4 corners with the stock dampening, it was recommended to me by a team driver, the car was planted, it had tons of steering and the back was not loose at all, very balanced.
I don’t know what the team drivers ended up running though.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 04-08-2010, 07:15 AM   #2150
dj apolaro's Avatar
This is what I would start with;
Front
#3 sway bar
1 hole piston in the shocks with 800wt oil (30%) rebound
blue spring up one from bottom, if traction is high lower them all the way
front diff 200,000 oil
-.5 droop
-1 each side for toe
1.5 camber
middle position for the roll center
Ackerman position, back and outer
1mm short
35 front tires
Rear
2.5 sway bar and shave the middle to 1.1. (This is a mod we have been using)
2 hole piston in shocks with 800wt oil (30%) rebound
pink springs laid down, if traction is low raise them 1 hole
camber link on tower 1 up from bottom. 2mm spacer on hub
3.5 droop
+2.5 of toe
camber 4 on left and 3.5 on right
sway bar on inner position on the lower part of the arm
all short
Let me know if I forgot anything,
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 04-08-2010, 08:48 AM   #2151
Hi DJ,
do u just grind a flat spot making it half circle thickness 1.1??
or grind it full circle so the diameter is 1.1?
and how wide for the 1.1?
thanks and a picture would be great
ck960 is offline   Reply With Quote
Old 04-08-2010, 09:50 AM   #2152
dj apolaro's Avatar
Hi DJ,
You have to grind a little form each side to make it 1.1. That way it is centered on the sway bay. Just try your best. Here is a photo. Aslo use some tape or something and just make sure to measure it with the collars that go over the bar and hold it in the bearings. Make sure to leave about 1mm of full bar on the inside of this collar.
Hope this helps,
DJ Apolaro
Serpent 733 1/10 200mm touring-rear-sway-bar-001.jpg
Old 04-08-2010, 05:10 PM   #2153
barg's Avatar
Send a message via Yahoo to barg
Front
#3 sway bar
-.5 droop
1.5 camber
1mm short
35 front tires
Rear
3.5 droop
+2.5 of toe
all short
DJ Apolaro
Hi DJ,
Can you explain the theory behind the mounting of the shocks?
I thought the lower the shock the more side bite it generates? Why do you stand them up in lower grip?
Thanks.
Andrew
XRAY NT1-2015 Spec | Max Power Engines | KO KIY EX10 | Protoform | Matrix Tires | XRAY X12-16
HEI International | www.hobbyexpress.com.au
www.nswrcrcc.com
barg is offline   Reply With Quote
Old 04-08-2010, 05:13 PM   #2154
barg's Avatar
Hi guys,
Just a question on bearings in this car. I have been told that they come oiled and not greased like most cars.
Do you clean and re-oil them every meeting?
The reason I asked is that I had a failure in a front bearing when the car was only 3 meetings old.
www.nswrcrcc.com
Old 04-08-2010, 05:43 PM   #2155
Hope this helps,
DJ Apolaro
Thanks,
i'll try this out see how it goes. i'm thinking this should improve the rear stability right?
Old 04-08-2010, 07:02 PM   #2156
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Hope this helps,
DJ Apolaro
Hi DJ,
Sorry if I missed it, but was it the theory behind this mod?
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 04-08-2010, 10:25 PM   #2157
dj apolaro's Avatar
The mod for the rear sway bar helps with the stable rear end.
The though of the springs is that in high bite I like the car to be softer and have a little more roll, as not to tractions roll. When the grip is lower the car needs help with response and the shocks a little stiffer helps this. Putting the shocks up one position helps in that way.
DJ Apolaro
Old 04-09-2010, 07:33 AM   #2158
Trader Rating: 16 (100%+)
Default Rear end keep throwing
Hi to all 733 drivers,
I m currently facing my rear end kept throwing,
seems like less grip at the back..
Any one have idea how to solve such issues??
I have try using thicker diff oil and lower shore tyres
but stil not working..
Anyone got any idea???
rossii is offline   Reply With Quote
Old 04-09-2010, 08:45 AM   #2159
Send a message via Yahoo to motojon
u can try adjusting rear toe also
My Gpa(RIP)
motojon is offline   Reply With Quote
Old 04-09-2010, 08:58 AM   #2160
Shouldn't you use thinner oil in the rear diff, to get the rear more stable?
ma_RC_el is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
