Old 03-17-2010, 04:22 AM   #2071
Alex Siddique's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Alex Siddique
measure it before u put the bottom arm on the bulk's. also not to worry much about the lengths ( keep it as close to same ) as when u tweak it will even the difference out .
No Fucker's Taking my money O/s OR local :) :)
Alex Siddique is offline   Reply With Quote
Old 03-17-2010, 04:26 AM   #2072
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 03-17-2010, 04:49 AM   #2073
Old 03-17-2010, 04:59 AM   #2074
Pattojnr's Avatar
Serpent - Walter RC
Old 03-17-2010, 05:07 AM   #2075
opps
Old 03-17-2010, 05:11 AM   #2076
Pattojnr's Avatar
Serpent - Walter RC
Old 03-17-2010, 05:15 AM   #2077
oopppps
Old 03-17-2010, 05:20 AM   #2078
Ballistik Mods's Avatar
serpent rules
Last edited by Ballistik Mods; 03-17-2010 at 05:46 AM. Reason: not relivant to subject
Ballistik Mods is offline   Reply With Quote
Old 03-17-2010, 05:25 AM   #2079
Originally Posted by mugen boy View Post
Hi guys just wanted to add my piece .i have to agree with alex he has been driving the serpent since it was released also and has spent a great deal of time on setup.his car as comented on buy others is very settled at moorebank and other tracks but i cant drive it .setup is personal and relitive to the input of the driver not other drivers.but ideas on setup may work ,the purpose of the forum is to chat and share information not to critisize someones input
what are you talking about .. make sure you have a good breaky sunday morning will be trying all the new hard plastic stuff with a new setup . lots of running around.
Old 03-17-2010, 05:35 AM   #2080
Pattojnr's Avatar
i dont think anyone needs to read what just happened, so i removed it all to not take away focus from the car.
Serpent - Walter RC
Old 03-17-2010, 09:48 PM   #2081
Trader Rating: 31 (100%+)
Originally Posted by rcpaintinpete View Post
YOU did nothing wrong .YES it will rub a little you can shave a bit off so it dont rub or get the ATOMIC Alu one it fits nice and the belt dont rub on it
http://www.rcatomic.com/atomic/index...emart&Itemid=1
Ok, so i got this and it rubs on the carbon top plate...What gives????
Scott
1968 Camaro: 1:1, 5.3L LM7, Complete Restoration in Progress
SC10 Brushless
RC10B64 Club Racer
sdphilips is offline   Reply With Quote
Old 03-17-2010, 10:19 PM   #2082
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Scott
I added 1mm shims to each of the 3 screws that mount the middle hub, this allows the belt to clear the steering post as it shifts the whole assembly slightly to the right (when looking front on at the car)
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 03-17-2010, 10:53 PM   #2083
barg's Avatar
Send a message via Yahoo to barg
Is that a trick you learnt building one of the 17 cars you have owned?
XRAY NT1-2015 Spec | Max Power Engines | KO KIY EX10 | Protoform | Matrix Tires | XRAY X12-16
HEI International | www.hobbyexpress.com.au
www.nswrcrcc.com
barg is offline   Reply With Quote
Old 03-17-2010, 11:21 PM   #2084
Michael_T's Avatar
Mate, trust me, after building my last car (I won't mention which German car it was ), the 733 is a dream to put together.
Funny enough, I had to pull out my dremel on the very first step putting the front solid together (couldn't slide the silver pulley adaptor onto the shaft), so I was starting to get flashbacks, but thats the only time I needed it during the whole build.
Old 03-18-2010, 05:36 AM   #2085
Toaster's Avatar
Default Rear Belt tension
Has anyone had any issues with the Rear Belt Tension?
- Chassis is straight
- Cam is as tight as it goes.
- Pulley 20
Toaster
Futuba 4PK, CAPRICORN C02 , TITAN TOOLS,MRCCR
Toaster is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
