Old 03-11-2010, 10:48 AM   #2041
DS Motorsport's Avatar
Originally Posted by ugglasdav View Post
i was thinking maybe the reciver box but dont know if it would fit. btw i am using the exceed regulator
If I'm not mistaken Julius has his Xceed regulator mounted in the receiver box and has been running it for quite some time.
So you might want to ask Julius if he had any problems with it overheating or something.
It does get quite hot, after a main mine is always pretty hot.
But it worked flawless the entire season last year.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 03-11-2010, 11:03 AM   #2042
Julius's Avatar
On my 720 I had the original xceed regulator mounted between the tank and pipe. That never was an issue, but I never thought of checking the temp...
On my 733 I'm using the newer small xceed regulator and it is mounted inside the receiver box. Heven't had issues yet. Ran a couple of 30 minute mains with it. But again I never thought of checking the temp What you don;t know doesn't scare you I guess
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 03-11-2010, 12:44 PM   #2043
ugglasdav's Avatar
well i only had my car switched on for about 10 mins and the reciver box was pretty warm, and that was on the outside. might double side tape it onto the reciver box outside.
>Shepherd Velox V8/Team associated TC5R
>>IDM 2011/ Speed passion/Much More
>>>Sanwa m11x
ugglasdav is offline   Reply With Quote
Old 03-11-2010, 02:52 PM   #2044
RC MARKET's Avatar
Futaba receiver can't over 45 deg C !
RC MARKET is offline   Reply With Quote
Old 03-13-2010, 07:29 AM   #2045
shamu's Avatar
What brand of life receiver batt fits in the 733,I'm sure it is in an earlier post, just dont have the time to look for it thanks.
CHARLIE SCHAUMBURG
XRAY NT1 2013 / FORDHAM HOBBIES / HOT RACE TYRES/ Port Jervis NY Onroad Raceway/ FLOYD BENNET RACEWAY / McPappy Racing /
shamu is offline   Reply With Quote
Old 03-13-2010, 01:36 PM   #2046
Send a message via ICQ to CivicTuning
Hi guys,
I have just built mine, engine is a Novarassi 3-CT and what i noticed is that the side belt is running extremly close if not too close to the exhaust just near the engine.
Anyone else has that problem too ?
Thanks.
Greetz,
Christoph
Capricorn LAB-C801
RB CX-R
Futaba 4PK
CivicTuning is offline   Reply With Quote
Old 03-13-2010, 03:34 PM   #2047
roscoe 141's Avatar
Thumbs up side belt
Originally Posted by CivicTuning View Post
Hi guys,
Thanks.
Greetz,
Christoph
if if you to page 24 of manuel it show you to place belt tensher on top dont place it on bottom of radio tray.
roscoe 141 is offline   Reply With Quote
Old 03-13-2010, 03:44 PM   #2048
RC MARKET's Avatar
Intellect IP
Li-Fe 1200 or 1450mah
Old 03-13-2010, 08:00 PM   #2049
NiTrO BoOsTeR's Avatar
i just built my 733 and im running a Novarossi 3SCT tuned, and found the same problem, the instructions tell you to run the tensioner on top of the radio tray, this left the belt very loose and it rubs on the exhaust header, i moved the tensioner to under the radio tray and now it takes up the slack in the belt better and also stops the belt rubbing on the header.
Mitchell
Serpent 733 - RB T10rc - Ko Helios EX-10
Serpent 733 - Novarossi 3SCT Tuned
============== SERPENT the only way ============
==== Pro Buggy Rc, Pitsworth - for all my RC needs =====
NiTrO BoOsTeR is offline   Reply With Quote
Old 03-13-2010, 11:47 PM   #2050
Alex Siddique's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Alex Siddique
Mitchell
i found you need the slack , just my experience . i use a 1/8th tension pulley . leaving the holder on top . works well .
No Fucker's Taking my money O/s OR local :) :)
Alex Siddique is offline   Reply With Quote
Old 03-14-2010, 08:17 AM   #2051
Mitchell
hi, im joe from malaysia....in malaysia we all just do the same way like u said before, move the tensioner under the tray and the problem is solve.....
..joe..
**JOE**
joe_hyreel is offline   Reply With Quote
Old 03-14-2010, 11:37 AM   #2052
canduran's Avatar
Send a message via MSN to canduran
Hi,
Yes,To move the tensioner under the tray and it is perfect.
Serpent 411
Kopropo
canduran is offline   Reply With Quote
Old 03-14-2010, 02:55 PM   #2053
G87z's Avatar
Originally Posted by G87z View Post
Hello,
Has anyone put in some decent time using the Hard suspension parts? I was wondering what you did/didn't like about them. Are they more durable than the normal parts. etc etc.
Thanks!
Anyone??
Team Shepherd USA / Picco Engines / Sanwa / Matrix Tires / Byrons Fuel / SRC
G87z is offline   Reply With Quote
Old 03-14-2010, 04:41 PM   #2054
Thanks for the tip everyone !
Will try to put the belt tensioner under the radio tray.
Greetz,
Christoph
Capricorn LAB-C801
RB CX-R
Futaba 4PK
Old 03-15-2010, 04:48 AM   #2055
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Guys, quick question.
I am up to the brake assembly, and the piece circled is not included in the bag
Will I find it in another bag further during the build, or should I order one?
Serpent 733 1/10 200mm touring-untitled.jpg
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
