Old 03-08-2010, 07:15 PM   #2026
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
white- 13lbs yellow=16lbs orange=19.5 red=23.5 pink=28 blue=33 purple=39 green=45.5 grey=51.5 black=57
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 03-09-2010, 03:13 PM   #2027
RC MARKET's Avatar
RC MARKET is offline   Reply With Quote
Old 03-10-2010, 12:52 PM   #2028
Julius's Avatar
Originally Posted by nitrodude View Post
Good Job Paolo!!
Does anybody have the spring rate chart? I searched but cant find it, and I lost mine.
I think this is what you're looking for?
Thanks to the original maker...
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 03-10-2010, 01:27 PM   #2029
nitrodude's Avatar
Julius, you da man!! Thats exactly what I was looking for.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 03-10-2010, 01:59 PM   #2030
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Hey steve, Here is some easy stuff for spring rate calculations.
The formula for calculating the spring rate of a compression spring is the following:
K= G*d^4/8*D^3*n
where:
K= Constant, load of pounds per inch of deflection
G= Modulus of rigidity (80.000 N/mm^2 for springsteel)
d= wire diameter
D= mean coil diameter: outer diameter- wire thickness
n= number of active coils
So all of these variables influence K, the actual springrate.
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 03-10-2010, 04:04 PM   #2031
ugglasdav's Avatar
hey guys. had my regulator in my car for the first time. i placed it in the reciver box with my reciver and after about 10 mins the reciver box was realy warm and was just wondering were do you guys put your regulators?
>Shepherd Velox V8/Team associated TC5R
>>IDM 2011/ Speed passion/Much More
>>>Sanwa m11x
ugglasdav is offline   Reply With Quote
Old 03-10-2010, 04:33 PM   #2032
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Just to clarify, the 733 comes with BLUE front, and RED rear springs?
The standard default setup says blue front, but the exploded instruction diagram says purple.
Even a female couldn't tell the difference of these colours looking at the springs
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 03-10-2010, 06:38 PM   #2033
lil-bump's Avatar
Trader Rating: 83 (100%+)
You should always mount a regulator in open air. It needs to be cooled by open air.
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 03-10-2010, 07:14 PM   #2034
Alex Siddique's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Alex Siddique
hi mate,
Blue front red rear is the stock , good idea to carry pink , purple , orange and yellow . You will need orange at Moorebank . Book setup was not drive able on our track too much steering .
regards
alex
No Fucker's Taking my money O/s OR local :) :)
Alex Siddique is offline   Reply With Quote
Old 03-10-2010, 09:20 PM   #2035
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by ccrcraceway View Post
hi mate,
regards
alex
purple fronts, red rears, and a spool up front. ccr.... send me that email
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 03-10-2010, 09:35 PM   #2036
The editable setup steet will not let me save the setup . if you got a sheet that can be edited and saved email it to me . [email protected]
Old 03-11-2010, 12:13 AM   #2037
Pattojnr's Avatar
do a search for a pDF printer, install it, when you fill out the sheet, print it. select the pdf printer and it prints to file. then you can send it.
Serpent - Walter RC
Old 03-11-2010, 01:05 AM   #2038
ugglasdav's Avatar
where do you guys normaly put your regulators then?
>>>Sanwa m11x
Old 03-11-2010, 02:30 AM   #2039
i Dont use one . i use lipo LiFe bat. no need of 2 meters of wiring . or worry about frying the regulator . a cheaper than a regulator setup
Old 03-11-2010, 10:31 AM   #2040
ugglasdav's Avatar
i was thinking maybe the reciver box but dont know if it would fit. btw i am using the exceed regulator
>>>Sanwa m11x
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
