Old 02-08-2010, 02:04 PM   #1891
Julius's Avatar
Originally Posted by rcpanama View Post
Hi, I have a question, I am running my 733, in a very technical parking lot runway, the traction is low, my car is doing very good, but I will like to get a little more rear traction getting out of the corner (on Throttle).
The first thing it comes to my mine, is increase the Front Anti-roll Bar.
I am using the stock 2.5mm in front, my question is:
Should I used the same 2.5mm, and just harden the set up of this Anti-Roll Bar, or change it, to 2.8mm.
My Set Up is:
Front Diff 100,000
Rear Diff 30,000
Front Spring RED
Rear Spring BLUE (Long)
Front tire 37 60mm
Rear tire 40 62mm
Front Camber 1.5
Rear Camber 3.0
RCPANAMA
I'd go with nitrudude's suggestion for a softer rear bar (or the inner holes on the arm if you're outside)
Then, go to the lowest rear shock mounting hole if you are the default second hole from bottom.
A mm less caster can do amazing things sometimes
Without seeing the entire setup sheet it is a bit hard to be more specific.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 02-08-2010, 04:42 PM   #1892
rcpanama's Avatar
Thanks, Julius, this is my Set Up
Spur
59/17
55/22
Gear Diff
Front 100,000
Rear 30,000
Shocks
Front one hole 35 oil Blue
Rear two holes 35 oil Red
Shock mountin
Front second hole front boton
Rear Second hole front boton
Anti Roll Bar
Front 2.5 (2mm)
Rear 2.5 (0mm)
Tire
Front 37 / 60mm
Rear 40 / 62mm
Engine
Novarrosi +12 3SCT Murnan
Roll Center
Front Midle hole
Rear Boton hole
Caster
3mm
Camber
Front 1.5
Rear 3.0
To in out
Front -1.0
Rear 3.0
Down Stop
front -1mm
Rear 4mm
Ride Hight
Front 5mm
Rear 6mm
Ackerman
out front
Stiffners
front screws NO
Rear Screws NO
Track Width
Front 198
Rear 199
RCPANAMA
Serpent 720 Novarossi Murnam 12 + 3CT Full Ceramic & 2630 pipe. 733 Novarossi Murnam 12 + 3SCT full ceramic & 2660 pipe , Nomadio Sensor, Xceed Lipo, Xceed Tires Japan Foam
rcpanama is offline   Reply With Quote
Old 02-08-2010, 08:27 PM   #1893
keavze's Avatar
i would up the rear diff to 50k and try...
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 02-08-2010, 08:33 PM   #1894
rx7ttlm's Avatar
Trader Rating: 30 (100%+)
Probably not the correct direction since he wants more rear end grip off the corner. More rear toe, lay shock down, lower rear roll centers, soften shock oil, softer rear spring, wheel base change or softer rear diff oil.... is more in the direction he is asking for..
|Team Xray | RC America |MAX Engines | Hudy |Jaco | KO PROPO |"From Slovakia with Love" T3 | Team Timezone |
Timezone Raceway & Hobbies - http://www.timezonehobbies.com
rx7ttlm is offline   Reply With Quote
Old 02-08-2010, 09:32 PM   #1895
wingfloat's Avatar
How do you know, you don't even Run Serpent or Own one.
wingfloat is offline   Reply With Quote
Old 02-08-2010, 09:52 PM   #1896
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
You really think that matters what kind of car he runs?
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 02-08-2010, 09:58 PM   #1897
Team-RTR's Avatar
thats quite possibly the stupidest post i have ever read on rctech.
GTFO of the thread if thats the intillectual capacity your going to show, everyone is now stupider for reading your post.
SERPENT | NOVAROSSI | XRAY | TEKIN | FUTABA
Team-RTR is offline   Reply With Quote
Old 02-08-2010, 10:24 PM   #1898
keavze's Avatar
well...it works for me. in fact i'm running 80k rear diff. with rear long pink springs!
i feel that if you 'soften' the rear too much, you'll lose out of corner 'punch' and car feels 'slugglish' in turning. well that's just me.
my opinion: if the rear is 'settled' enough, you'll actually gain grip.
Old 02-08-2010, 10:51 PM   #1899
ShermanSim's Avatar
ShermanSim is offline   Reply With Quote
Old 02-08-2010, 11:09 PM   #1900
rx7ttlm's Avatar
Originally Posted by ShermanSim View Post
hey sherman, hows the pizza business?
Scott- hows the weather in your neck of the woods? Are you guys racing yet?
I was just going on what he asked for, more rear end grip..
Old 02-09-2010, 04:34 AM   #1901
gfilos's Avatar
which grease would you recommend for diff orings, so as to provide a good seal? also for the silicone rings in rccx absorbers?
gfilos is offline   Reply With Quote
Old 02-09-2010, 08:28 AM   #1902
nitrodude's Avatar
You dont need any grease, the work just fine.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 02-09-2010, 12:27 PM   #1903
ShermanSim's Avatar
[QUOTE=rx7ttlm;6978267]hey sherman, hows the pizza business?
Hey, what's up? are you still in Colorado?
when are you visiting LA again?
Regards
Serpent America, 977 KO Radio, Nova Rossi Engine, Kosmic Fuel
Old 02-09-2010, 02:33 PM   #1904
rx7ttlm's Avatar
[QUOTE=ShermanSim;6980747]
Regards
Nah, I am in oregon. That's why I am itching to run nitro, because its raining to much to race outdoor. I hope to get down there this summer.
Old 02-11-2010, 01:52 PM   #1905
Hy,
i have 2 questions:
Whats the better rear spring for the 733 ? long or short ?
Whats do you change with the différents position on servo saver ? ackerman , ok but long= more ackerman ??? and the outter or inner position.
thanks for answer
P.S. : julius , if you have a good start set-up for the europeen track , i take it ;-).
Thanks for all
Michel Tomagra from belgium
mitchtomagra is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
