Old 02-05-2010, 12:22 AM   #1861
keavze's Avatar
Originally Posted by Ultraspeed84 View Post
What parts are weak on the 733 that i would need to keep in stock? to take to the track with me.. ill be racing more low traction type tracks is the serpent good or whats the low down?
i've got the pioneer batch of 733 and the only thing that i've broke till now are the belts...
gears, arms, belts and wheel hubs are my spares.
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 02-05-2010, 10:19 AM   #1862
http://www.rc-toro.com/product_info....94b16ce812b38b
Anyone tried the CSO hopups for 733? Looks nice tho
silverM3 is offline   Reply With Quote
Old 02-05-2010, 12:08 PM   #1863
Android's Avatar
So you got it in finally? Someone told me that You are the owner of RC-TORO
Correct?
Android is offline   Reply With Quote
Old 02-05-2010, 01:40 PM   #1864
What would you say about the stock brake disc?
IMO it's not so good and little bit not straight.
Did you test CSO, Xceed or Optional Serpent brake?
I need to have one of these, but I don't know which one exactly.
FranQBs is offline   Reply With Quote
Old 02-05-2010, 08:04 PM   #1865
TIX
TIX's Avatar
Trader Rating: 17 (100%+)
what is the center to center distance between the mounting holes on the serpant brake disc. the holes that are used to the brake pully adaptor
Alan Nankervis.
TIX Race Designs. Plaig Bearings. Thunder Innovations
TIX is offline   Reply With Quote
Old 02-05-2010, 08:31 PM   #1866
Default 733 easy to drive?
hi to all 733 drivers,
i m pretty keen on the 733. may i know is the serpent 733 easy to drive of the box with the stock setting ?? mind to share???
kungfupanda1198 is offline   Reply With Quote
Old 02-06-2010, 02:46 AM   #1867
Julius's Avatar
The car is very easy to drive with stock setup. No options needed. Also, the car has a large range where it works well.
My current setup is still very close to stock.
One of the big advantages to the 733 is the open design. This makes everything easy to clean and maintain.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 02-06-2010, 03:59 AM   #1868
Team-RTR's Avatar
just purchased my 733 today, and upon checking out hte contents i noticed i received the hard suspension parts in the box aswell as the normal ones, and was just wondering what most people are running for med-high grip tracks?
Thanks guys.
SERPENT | NOVAROSSI | XRAY | TEKIN | FUTABA
Team-RTR is offline   Reply With Quote
Old 02-06-2010, 04:23 AM   #1869
Julius's Avatar
Thanks guys.
The "h" marked hard suspension parts are about as stiff as the stock ones. Just try to feel the difference by trying to bend the parts by hand. However the "h" marked parts ar made from a different material which will be much more crash resistent.
For high/med grip tracks the "h" parts are good. There will be a softer version suited for low/med grip tracks soon
Old 02-06-2010, 04:34 AM   #1870
Default ?
thanks bro. yeah hope it wil be easy to drive..
stil deciding to jump back to touring.
Old 02-06-2010, 10:52 AM   #1871
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
where is the best place to buy parts for the serpent?
yokomo yz-2
Ultraspeed84 is offline   Reply With Quote
Old 02-06-2010, 12:01 PM   #1872
nitrodude's Avatar
http://www.kamikazetoysandhobbies.com/serpent.htm
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 02-06-2010, 09:44 PM   #1873
just bought my serpent with a max power motor and pipe.. im excited big time!
yokomo yz-2
Old 02-07-2010, 01:29 AM   #1874
Team-RTR's Avatar
hey guys quick Q, upto assembling my diffs, and my front binds pretty heavily when turning the outdrives by hand.. i have checked to make sure the screws in the diffs are in tight enough etc. and i was just wondering if it will be tight for a little while while they are running in or is there something else i should be checking?
Old 02-07-2010, 03:37 AM   #1875
Check if you mount the excentric (tensioner) in the same position left and right...
Cobra zz
Cobra zz is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
