Old 01-27-2010, 06:07 PM   #1831
NitroWD's Avatar
Lightbulb clutch: preload vs gap
I was rebuilding my clutch and was wondering: example...
Spring preload 0.8mm with 0.7mm gap vs preload 1mm with 0.5mm gap; what's the effects?
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 01-28-2010, 08:50 PM   #1832
trickd122's Avatar
Clutch gap is the amount that the clutch shoe moves before it contacts the clutch housing; this affects the WAY that the clutch engages more than WHEN it engages. Spring Preload affetcs when, the RPM range prior to engagement.
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 01-29-2010, 12:44 AM   #1833
NitroWD's Avatar
ok i understand.
so which of my example will give me more 'punch' out of a corner?
1. Spring preload 0.8mm with 0.7mm gap or
2. preload 1mm with 0.5mm gap
Old 01-29-2010, 02:17 AM   #1834
M7H
M7H's Avatar
Serpent
M7H is offline   Reply With Quote
Old 01-29-2010, 02:24 AM   #1835
M7H
M7H's Avatar
BUT,
If the spring you have is a softer type, the amount of pre tension you have to put on it to let it engage on the correct RPM might result in a clutch with slip, because the maximum distance the clutch shoe can move depends on the maximum distance the spring has left before it's fully compressed....
Serpent
Old 01-29-2010, 04:27 PM   #1836
RC MARKET's Avatar
1. STD Spring w/0.7mm gap
RC MARKET is offline   Reply With Quote
Old 01-29-2010, 07:11 PM   #1837
Pattojnr's Avatar
Trader Rating: 19 (100%+)
the 09 720 and 733 comes with the 1.8 clutch spring in the kits.
i find that on a lower grip track , the 1.7 from the 08 or older 720 works best. the 1.8 spring is just too much for a lower grip track.
i use the 1.7 spring, 0.7 preload and a gap of 0.6. its a nice smooth engaging clutch that wont upst the rear of the car getting on throttle, and it is very consistant. for sure high grip use the 1.8 and you can afford to be agressive with the settings, but for anyone on a low grip track , try this clutch setting, it really works well.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 01-29-2010, 10:11 PM   #1838
Bundy_Bear's Avatar
What are the arms with H etched into the plastic in white?
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 01-29-2010, 10:20 PM   #1839
Alex Siddique's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Alex Siddique
New Harder Material construction parts.
No Fucker's Taking my money O/s OR local :) :)
Alex Siddique is offline   Reply With Quote
Old 01-29-2010, 10:27 PM   #1840
Bundy_Bear's Avatar
Does this mean the other ones are weak?
MissMooRC Racing
Old 01-30-2010, 12:17 AM   #1841
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
Not weak just softer. The "H" arms are made from a stiffer plastic but they also change the handling of the car cause of their stiffness.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 01-30-2010, 01:47 AM   #1842
RC MARKET's Avatar
804206 - 804209
Old 01-30-2010, 02:18 PM   #1843
RC MARKET's Avatar
If in lower traction track ,
first choice 32 or 35 shore tire ,
if same lower grip use Parragon Ground Effect
Spring can softer & 0.8mm / gap 0.4-0.6 only !
will had smooth & turn 0-80%+ had punch & response ,
but need keep rebuild your engine !
change your engine bearing !
What Engine ?
Old 01-30-2010, 09:19 PM   #1844
Pattojnr's Avatar
What Engine ?
softer tire = more tyre wear. cant do that as track is too hard on 40's never mind 32 ! not allowed to use tire additives.
clutch spring is the thing to change. engine bearings ? hahaha doesnt effect car grip.
next time, try the clutch spring.
Serpent - Walter RC
Old 01-30-2010, 09:43 PM   #1845
spurgear's Avatar
Send a message via MSN to spurgear
saw these new goodies from serpent for my 733. Nice!
Serpent 733 trinirc.com
Novarossi Plus 12-3CT Murnan Modified Full Ceramic Edition
Novarossi EFRA 2630 exhaust with medium header
Futaba 3PK HRS with Digital Servos/ JLR Starter Box
East Civic 200mm
spurgear is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
