Old 01-22-2010, 05:39 AM   #1816
Julius's Avatar
Originally Posted by NitroWD View Post
I did what patto mentioned, just need to 'elongate' the sirio engine mounting hole inner and it'll fit the original mount. The problem is that the throttle would hit the radio plate and tank, need to shim the engine higher.
Patto: where and how much to shim?
By the way, the serpent sirio mount is of the same height as the original mount, I wonder how will it raise the engine for the throttle to clear?
The only difference I could find is just that the sirio mount got the holes aligned for sirio engines...
Here are two pics from one of our team drivers.
One shows a mod to the pipe to get more clearance to the stering arm. The other shows engine mounting. He angled the carb slightly to get correct clearance.
Hope this helps, as an addition I'd look into using an M3 setscrem from the side in the pipe to fix it to the holding spring. Might be a bit beefier then the small thread left in the front of the pipe.
Serpent 733 1/10 200mm touring-daan-sirio-uitlaat.jpg   Serpent 733 1/10 200mm touring-daan-siro-motor.jpg
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 01-22-2010, 05:43 AM   #1817
Pattojnr's Avatar
Trader Rating: 19 (100%+)
mine was actually the Capricorn 12. same engine case though as an evo 4. the xxx may be a little different. shimming wasnt much. like a 1mm shim on each screw at max.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 01-22-2010, 05:44 AM   #1818
Pattojnr's Avatar
not much foam on those wheels
Serpent - Walter RC
Old 01-22-2010, 09:08 AM   #1819
NitroWD's Avatar
Hey, I managed to fit my sirio with original mount into my 733 without any shims or modification to the mount! Howver the throttle will touches the fuel tank at full throttle...
Shouldn't be a problem though, will be testing it this sat.
* Earth's fate depends on what we do TODAY... *
+ Earth got all the time in the world; but we DON'T... +
NitroWD is offline   Reply With Quote
Old 01-22-2010, 11:53 AM   #1820
Julius's Avatar
Quite possibly rotating the carb a little helps resolve the clearance issue.
Old 01-22-2010, 11:54 AM   #1821
Julius's Avatar
Who ever said team drivers don't fully use their stuff!
Old 01-23-2010, 02:37 PM   #1822
RC MARKET's Avatar
good tips !
RC MARKET is offline   Reply With Quote
Old 01-23-2010, 04:05 PM   #1823
Suspended
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
Default MACHINED ALUMINUM 733 MOTOR MOUNTS
OK. some of us have been breaking the stock motor mounts,
I have a friend that owns a machine shop and he is machining
some out of aluminum. If anyone is interested,
I'm taking pre orders on them so I know how much raw material
to get. They will cost $45 a set + $5 shipping. to the U.S.
These will be a direct fit part - no modifications will
be necessary. Please feel free to PM me or email me at
[email protected]
TEAM ARC USA --- TEAM POWERS USA ---- TEAM VALKARIA RC ----
rcpaintinpete is offline   Reply With Quote
Old 01-23-2010, 04:23 PM   #1824
rmdhawaii's Avatar
BREAKING MOTOR MOUNTS???!!!
Nitro Knowledge Base: http://nitrokb.netne.net
My YouTube Channel: http://www.youtube.com/nitrokb -> Lots of on-road nitro & eletric action + some off-road as well
My Flickr Photostream: http://www.flickr.com/photos/nitrokb/
Kyosho V-ONE RRR WC (x2) \ XRAY T2'007 \ Also owned: XRAY NT1 & Mugen MTX-4
rmdhawaii is offline   Reply With Quote
Old 01-26-2010, 09:21 AM   #1825
serpentamerica's Avatar
NOVAROSSI CHALLENGE IN CALIFORNIA
Congrats to Scott Kimbrow for his performance @ the Novarossi Challenge. First time out with his Serpent 733 and he finished second. Way to go!
Serpent 733 1/10 200mm touring-podium-sedan.jpg
Facebook: http://www.facebook.com/pages/Miami-FL/Serpent-America/120322987992068
www.serpentamerica.com
e-mail: [email protected]
telf: 1-305-677-3253
serpentamerica is offline   Reply With Quote
Old 01-26-2010, 10:23 AM   #1826
rmdhawaii's Avatar
That's great!
Old 01-26-2010, 11:22 AM   #1827
wingfloat's Avatar
[email protected]
Can you please explain how some of you guys break motor mounts?
Need to Know.
wingfloat is offline   Reply With Quote
Old 01-26-2010, 03:39 PM   #1828
Suspended
Need to Know.
I wish I could give you a good reason, but I can't.
I believe they are breaking during crashes.
I do not know how the tracks are where you race, but in
Florida we have very hard boards and metal partitions on our
tracks. I don't have any pics of my broken mounts, as I threw
them away at the track. Maybe someone else on here
does. I must not be the only one, as I have already taken
several pre-orders from people that have broken their's. Hope this
helps you out.
Old 01-26-2010, 03:46 PM   #1829
Kyle Hazell's Avatar
Trader Rating: 17 (100%+)
helps you out.
We have broken 2 rear mounts as well, both in the same place. Our thoughts are the mounts flex more when running without the 2 rear screws to make the chassis softer.
We have been running with the 2 rear screws back in now with a replacement mount and it appears to be fine.
Regards
Kyle
ARC R8 RB - Blitz Kronos Tyres - Futaba
Kyle Hazell is offline   Reply With Quote
Old 01-26-2010, 05:02 PM   #1830
dj apolaro's Avatar
[email protected]
Hey Pete,
I will take one!!!!
Thanks for gettting this made. Next is a light weight 2 speed shaft.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
