Old 01-10-2010, 06:28 AM   #1771
Pattojnr's Avatar
Trader Rating: 19 (100%+)
if you strip a front belt, then the rear of the car drives. so if your coming out of the corner, its like rear wheel drive, very hard to control. but it would be like that every corner, every time. not if the belt is jumping , then it can be erratic when it happens. also what rear diff oil are you using ? and check the simple things , like dog bones arent binding when the suspensio is compressed. best way to check, is push down till the chassis bottoms out, and grab each bone, and see if it still has some movement from side to side.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 01-10-2010, 06:40 AM   #1772
Alex Siddique's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Alex Siddique
Nothing is binding i have checked it many times , it definitely feels like a rear wheel drive at every corner exit makes more sense . Corner entry and mid is always very good and the rest of the drive is excellent , but exit is always heavy over steer . i am using stock diff rear and 100K kyosho front diff. i will check out the belts tomorrow.
Thanks for all the help guys
No Fucker's Taking my money O/s OR local :) :)
Alex Siddique is offline   Reply With Quote
Old 01-10-2010, 06:02 PM   #1773
keavze's Avatar
yr rear diff too soft; try 60k or 80k...
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 01-10-2010, 08:54 PM   #1774
spurgear's Avatar
Send a message via MSN to spurgear
nice product
http://www.redrc.net/2010/01/cso-966...ht-brake-disc/
Serpent 733 trinirc.com
Novarossi Plus 12-3CT Murnan Modified Full Ceramic Edition
Novarossi EFRA 2630 exhaust with medium header
Futaba 3PK HRS with Digital Servos/ JLR Starter Box
East Civic 200mm
spurgear is offline   Reply With Quote
Old 01-10-2010, 09:46 PM   #1775
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
+1 need two of these asap Sam
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 01-12-2010, 09:15 PM   #1776
ShermanSim's Avatar
Default 733 New Rear Bracket
have anyone used the new rear bracket for the 733, if do , notice any difference on handling?
thanks
Serpent America, 977 KO Radio, Nova Rossi Engine, Kosmic Fuel
ShermanSim is offline   Reply With Quote
Old 01-12-2010, 11:59 PM   #1777
A little bit more stearing and less flex in the rear between the gearshaft and rear diff.
Pertn is offline   Reply With Quote
Old 01-13-2010, 03:16 AM   #1778
Which belts is better orange or the low friction once?
Old 01-13-2010, 04:28 AM   #1779
Pattojnr's Avatar
the orange belts last longer.
but the low friction ones roll better .
Serpent - Walter RC
Old 01-13-2010, 12:59 PM   #1780
Old 01-13-2010, 11:48 PM   #1781
keavze's Avatar
use the black to qualify and orange for mains...
my front and rear are orange while my side is black!
by the way, anyone knows the length of the rear dog bones? and which other dog bones fit?
Old 01-15-2010, 09:26 AM   #1782
Nitro Boy's Avatar
Send a message via ICQ to Nitro Boy Send a message via Skype™ to Nitro Boy
Hi
Does anybody have set up for lostallo,Switzerland (for 733 of course =))
if no=( what could you advice me for this track?
Nitro Boy is offline   Reply With Quote
Old 01-15-2010, 10:55 AM   #1783
Default 733
Empty post
Old 01-15-2010, 10:56 AM   #1784
nitrodude's Avatar
Originally Posted by Nitro Boy View Post
Hi
Send me the plane ticket and Ill go help you set up
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 01-15-2010, 11:05 AM   #1785
DS Motorsport's Avatar
Hi
A Murnan engine, that will be around 80% of the setup.
P1-RC.com
DS Motorsport is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
