Old 01-06-2010, 11:34 AM   #1756
Julius's Avatar
the loop out of the body is illegal in ifmar and efra. nothing except the arial may stick out.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 01-07-2010, 03:47 PM   #1757
Suspended
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
Default TANK STRAP
well thanks guys this was good info
did not the loop out of the body is illegal in ifmar and efra.
and I dont like the way it looks
TEAM ARC USA --- TEAM POWERS USA ---- TEAM VALKARIA RC ----
rcpaintinpete is offline   Reply With Quote
Old 01-07-2010, 11:40 PM   #1758
tcmodels's Avatar
updated pictures, pls
www.tcmodels.net - online hobby shop
tcmodels is offline   Reply With Quote
Old 01-08-2010, 07:59 AM   #1759
ttso's Avatar
http://www.redrc.net/2010/01/serpent...pension-parts/
Hard suspension arms??? hey I thought we are having softer one first...
ttso is offline   Reply With Quote
Old 01-08-2010, 10:48 AM   #1760
YR4Dude's Avatar
Trader Rating: 44 (100%+)
I think the previous parts were made of composite of carbon filled polystyrene and polypropylene. Most likely if they were to make it softer they would up the polypropylene content.
http://findarticles.com/p/articles/m.../ai_n31587189/
The new arms have nylon in the mix as opposed to carbon. Hard nylon is pretty tough if anyone remembers the days of the RC10 which had nylon parts. I think the new material is probably better and far more durable kind of like the RPM suspension arms for the monster trucks and offroad cars.
http://www3.interscience.wiley.com/j...38271/abstract
YR4Dude is offline   Reply With Quote
Old 01-08-2010, 05:08 PM   #1761
Would the new orange belts for 733 fit the old Serpent 710?
thanks in advance
silverM3 is offline   Reply With Quote
Old 01-09-2010, 05:24 AM   #1762
Julius's Avatar
thanks in advance
No. None of them will fit.
Old 01-09-2010, 07:18 AM   #1763
G87z's Avatar
Anyone know where I can get a Serpent Hoodie? It is COLD up here in NJ.
Team Shepherd USA / Picco Engines / Sanwa / Matrix Tires / Byrons Fuel / SRC
G87z is offline   Reply With Quote
Old 01-09-2010, 09:40 AM   #1764
serpentamerica's Avatar
we should get it late next week
Facebook: http://www.facebook.com/pages/Miami-FL/Serpent-America/120322987992068
www.serpentamerica.com
e-mail: [email protected]
telf: 1-305-677-3253
serpentamerica is offline   Reply With Quote
Old 01-09-2010, 08:10 PM   #1765
Alex Siddique's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Alex Siddique
Default over steer
my 733 seem to like harder tires in the front , if i run softer or same shore as rear tires i have uncontrollable over steer getting out of any corner ( i have tried many clutch setting and setup ), high or slow speed . has any one experienced the same ?
Cheers
Alex
No Fucker's Taking my money O/s OR local :) :)
Alex Siddique is offline   Reply With Quote
Old 01-10-2010, 01:13 AM   #1766
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Cheers
Alex
i found my steering links where hitting the bulkheads near full lock. once i changed some things, to give some clearance, the rear end settled down a fair bit. i also then used the 1.7 clutch spring from the 720 08, and raised the rear roll centre a little (more angled rear top arm) and it was close to where i want it.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 01-10-2010, 01:47 AM   #1767
Julius's Avatar
Cheers
Alex
I think your experience is opposite to most others. I think the 733 needs one step softer fronts. Or max same shore as rear.
One thing apart from setup might be to check belt tension. If you go too lose you might lose part of the front drive under hard acceleration. This leads to massive on throttle oversteer.
Old 01-10-2010, 02:35 AM   #1768
musti72's Avatar
Wow, I have never thought about it before. You are talking about front and side belt, right?
Mustafa Alp
http://www.aytemizhobi.com
Turkish shop for: Serpent, Xceed, Sweep Racing, MyLaps
musti72 is offline   Reply With Quote
Old 01-10-2010, 03:39 AM   #1769
Julius's Avatar
Yes. A rather crude way of checking is holding the front wheels and trying to turn the rears. This should take considerable force. If they can be easiliy made to skip you should increase tension.
Old 01-10-2010, 06:17 AM   #1770
I did have all the belt tension to the max lose setting . hummm definitely a very good point to check out . but i am hoping its not the case had about 30 sets of tire with softer front tires combo that i just got ride of. What do u mean by losing a part of the front drive ?
thanking you
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
