Old 12-24-2009, 12:54 PM   #1711
Suspended
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
Default MERRY CHRISTMAS
WOULD LIKE TO WISH ALL MY SERPENT PALS
A HAPPY & SAFE MERRY CHRISTMAS
TEAM ARC USA --- TEAM POWERS USA ---- TEAM VALKARIA RC ----
rcpaintinpete is offline   Reply With Quote
Old 12-24-2009, 09:33 PM   #1712
Pattojnr's Avatar
Trader Rating: 19 (100%+)
THanks again Julius, but a chart of comparisons would be good for shock and diff oils. just so when i change over to the new rated shock oil i know which one to start with.
Merry Christmas to all, have a great one.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 12-26-2009, 10:20 AM   #1713
I have to rebuild the CVD's on my car, but I dont know which pins i need to order. I believe they are the 3mm x 9.8mm pins (i dont have my car at work! ), but I am not sure. Does anyone know for sure if these are the proper pins?
Shawn.
Shawn68z is offline   Reply With Quote
Old 12-26-2009, 10:37 AM   #1714
Pattojnr's Avatar
Shawn.
802354 for pins yes 3x9.8
802352 for inserts
Serpent - Walter RC
Old 12-26-2009, 10:37 AM   #1715
Team Kamikaze's Avatar
Shawn.
The size of the pins are 2.0 x 9.8mm.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 12-26-2009, 11:50 AM   #1716
802352 for inserts
Thanks for the confirmation. January isnt even here yet, and I am already rebuilding my cars for April! Cant wait for outdoor season to start again.
Shawn.
Old 12-26-2009, 02:49 PM   #1717
Julius's Avatar
Shawn.
Just make sure you use the pins in the post by pattojr as they have square edges. these pins also exist in rounded edge format but those are not suitable for use in the cvds
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 12-26-2009, 05:02 PM   #1718
You mean Flat edge.
Old 12-27-2009, 02:06 AM   #1719
Julius's Avatar
30W = 350cst
35W = 600cst
40W = 1000cst
45W = 1400cst
50W = 2000cst
Diff oils are same for W and CST rating
Old 12-27-2009, 03:51 AM   #1720
Pattojnr's Avatar
30W = 350cst
35W = 600cst
40W = 1000cst
45W = 1400cst
50W = 2000cst
Thank you Julius .
Serpent - Walter RC
Old 12-27-2009, 04:29 AM   #1721
musti72's Avatar
802352 for inserts
How is the durability of those pins? I see Hudy/Xray pins wear very fast, so can it be a good replacement for Nt1 shafts?
Mustafa Alp
http://www.aytemizhobi.com
Turkish shop for: Serpent, Xceed, Sweep Racing, MyLaps
musti72 is offline   Reply With Quote
Old 12-27-2009, 04:41 AM   #1722
30W = 350cst
35W = 600cst
40W = 1000cst
45W = 1400cst
50W = 2000cst
To be more accurate:
Serpent oil (04-01-2005)
W cSt
20 107
25 207
30 370
35 626
40 1070
45 1449
50 2250
Oil tested was supplied by Serpent Benelux on 04-01-2005 and it was compared with a calibration oil.of 100 cSt.
Conclusion:
Serpent oil is way of linear with cSt rating
Thanks for River City!
FranQBs is offline   Reply With Quote
Old 12-27-2009, 04:42 AM   #1723
Pattojnr's Avatar
mine are fine. a diff is easier on them, you may need to replace them more often if you use a spool. the 8th scale ones dont last as long though
Serpent - Walter RC
Old 12-27-2009, 05:03 AM   #1724
NikoRacing's Avatar
Hi... some time ago I had the same problem with the NT1 but now I've solved.
You just have not to screw the pins with the 3x3 setscrew and so let it free. The ballbearing will keep the pin into the CVD. In this way the CVD will also be more free in the rotation, expecially in the corners and the pins will not over-wear.
NikoRacing is offline   Reply With Quote
Old 12-27-2009, 05:48 AM   #1725
musti72's Avatar
Patto and Nico, thanks for both advises, I was talking about the differential outdrive side(and rear wheel axle, I use dogbones at rear) I use diffs front and rear, and I use Tamiya VG joint cup grease on them. Even with a play of like 1-2mm, car's behaviour changed completely.
Then we bought a hudy pin replacement tool and hudy pins,and changed them.
Now they wear even faster!
I dont care much on front cvd pins, because its easy to change.
Mustafa Alp
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
