Old 12-21-2009, 11:58 AM   #1696
Team Kamikaze's Avatar
Originally Posted by mc_chofo View Post
Sam do you have the searing set in stock i just check your site and i didn't see them.
thanks.
Here: http://kamikazercracing.com/proddeta...rod=733CERAMIC
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 12-21-2009, 10:47 PM   #1697
Pattojnr's Avatar
Trader Rating: 19 (100%+)
Originally Posted by Pattojnr View Post
anyone tried changing the position the steering links attatch to the steering hub ?
for the life of me i cant run the forward outer Ackerman position in the servo saver with out the steering arms getting very close or touching the alloy bulkheads.
only way i have found to do it is the outer steering attatchment to go under the the hub, so the attatchment screw on top , and the linkage to the underside of the bearing block/steering hub.
would this effect the ackerman as well, due the arms being more flat as it steers ?
so no one is having the same issues with steering link setup ?
mine is stock as a rock, out the box. so what am i doing wrong ?
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 12-22-2009, 12:11 AM   #1698
Default RB R3
Originally Posted by DS Motorsport View Post
Well i'm really happy with the RB R3 (T9). I only have the RC versions but the regular R3 is used here as well.
The RB RC (or murnan) are the best .12 engines you can buy at the moment if you ask me.
The first time I ran mine and had the clutch set I was drifting out of pretty much every corner, the low end torque is ridiculous. Furthermore they have a really smooth powerband, almost like an electric motor. They are easy to tune and the stock version lasts quite some time, the rc wears out a bit quicker.
Hi,
How is the stock RB R3 compared to Novarossi Plus 12 3SCT when it comes to top speed? Also, is the torque on the stock R3 any good?
Would you say that 380 USD is a good price for this engine?
Regards,
Serpent
Serpent fan is offline   Reply With Quote
Old 12-22-2009, 12:35 AM   #1699
Alex Siddique's Avatar
Trader Rating: 30 (97%+)
Send a message via MSN to Alex Siddique
if i am understanding right . your end ball on servo saver must be at the bottom and on top on the steering block. And yes running them straight will take some steering away . by the way what front track width are you using ?
No Fucker's Taking my money O/s OR local :) :)
Alex Siddique is offline   Reply With Quote
Old 12-22-2009, 12:50 AM   #1700
Originally Posted by Serpent fan View Post
Hi,
Regards,
Serpent
The 12-3SCT 09' is only $299.99
Here: http://kamikazercracing.com/proddeta...prod=NOV123SCT
This engine have a lot of torque with great Top end, it is rated at 1.65 HP with a Maximum RPM of 42,400 RPM.
Old 12-22-2009, 01:27 AM   #1701
Pattojnr's Avatar
im running 198 at front, 2mm shorter wheelbase at front also.
i have the links as you say, but the problem being is when shocks are off, turn to full lock, with 60mm front tires on, and the rods hit the bulkheads, and unload the rear. i moved the ackerman backward last race to fix it, but lost initial turn in. so the only way i could see to do it, is attatch underside on the hub, then there is plenty of clearance.
Serpent - Walter RC
Old 12-22-2009, 03:39 AM   #1702
Julius's Avatar
A pic woud say a thousand words...
But, If I understand correctly, if you turn ie. full right and have the front of the car on the ground (suspension compressed) the right hand steering rod hits the right hand bulkhead, correct?
I'd believe this would be more so when the front narrow ackerman position is used (like I run the car), and longer wheelbase or less caster would make this happen sooner as well.
But I'd think that it being the inner wheel of the turn, it is not very likely it wil be fully compressed when you have full lock steering.
In stead of putting the outside of the rod underneath the steering arm (which kills steering geometry), just dremel a little material from the bulkhead. I believe it will take only a very small amount to get clearance.
To me this is more a bench racing issue than one that really is noticable at when driving. I do not see marks on my bulkheads but it may be a combination of setup details that aggrevates the problem for you.
Now I
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 12-22-2009, 03:58 AM   #1703
M7H
M7H's Avatar
Originally Posted by Julius View Post
Now I
Went to work?
Went shopping?
Have a power failure?....
Serpent
M7H is offline   Reply With Quote
Old 12-22-2009, 04:08 AM   #1704
Pattojnr's Avatar
Originally Posted by M7H View Post
Went to work?
Went shopping?
now I ?
have a different problem ? hahah
Thanks Julius. you got it right in how you think the problem is.
by moving the ackerman back, it gave clearance, and it settled my rear down. i did have marks on my bulkheads, after i noticed i had this issue.
i will dremmel the bulkhead a little to get clearance. i run the spool, so i dont use much caster, and maybe this is making the situation worse. but i would think 2mm shorter wheelbase would fix the issue as well, but it didnt.
thanks again.
Serpent - Walter RC
Old 12-22-2009, 04:09 AM   #1705
Julius's Avatar
Went to work?
Went shopping?
Need to check what I type before pressing send
Old 12-22-2009, 04:12 AM   #1706
Julius's Avatar
now I ?
thanks again.
With th rear ackerman, you'll get a less agressive feel in the steering. That could well be the reason the rear settled. If you have the time it might be a learning experience to do the dremeling at the track. That way you can check if, without changeing setup, the extra clearance makes a difference in handling.
Normally Dremeling at the track doesn't turn out as nice though
Old 12-22-2009, 04:16 AM   #1707
Pattojnr's Avatar
i will dremmel anyway. there are marks from rubbing / hitting the steering links. it happens about 3/4 lock. with shocks off. but the rubbing marks are evidence it has been touching. i drove at the Nats like this, and when i got back home. only last 2 meets i realised i had the issue. when i gav eit clearance, then the car was more settled. i like the ackerman forward, feels better. so i will dremmel. Cheers.
Serpent - Walter RC
Old 12-22-2009, 11:20 PM   #1708
Pattojnr's Avatar
Default Xceed oils
howdy guys,
just wondering if there is a comparison chart or something to compare the old Serpent WT rating, to the new cst rating. like 30,000wt diff oil, is rated as ??? cst. cheers.
Serpent - Walter RC
Old 12-24-2009, 06:45 AM   #1709
Julius's Avatar
howdy guys,
The diff oils were already in CST. So they should be the same, barring the variables between mfg.
Old 12-24-2009, 09:57 AM   #1710
RC MARKET's Avatar
CSO New Product
upper deck mount
Serpent 733 1/10 200mm touring-cso-ser-73320.jpg   Serpent 733 1/10 200mm touring-cso-ser-73320-1.jpg
RC MARKET is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
