Old 12-01-2009, 09:09 AM   #1561
Originally Posted by musti72 View Post
Is there anyone who can gauge the weight of 733's main and middle shafts, spur gear adaptors, differentials, and universals? Im trying to compare the transmission weights of the cars available today. I have stock and option xray parts' info, and waiting for the capricorn car.
You can take everything out of the car that rotates, shafts, pulleys, diffs, cvds, hexes, spur gears, everything (I excluded belts, bearings and the clutch when I did the same) and put them all on a scale. This doesn't really help you if you don't have it though, it's hard to say if someone included everything if you are getting your numbers from someone besides yourself.
The NT1 with every lightweight component at the time from xray with the multi spool/oneway was about 230g but the LW cvds were not out and I did not count aftermarket non-xray parts.
I was able to get a Kyosho RRR to 224g with an aluminum spool and other things but no titanium but it started off around the 260g mark as a straight rrr evo wc.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 12-01-2009, 10:38 AM   #1562
musti72's Avatar
Wow, good info there... You are right actually, but the heaviest parts of the transmission are main shafts, diffs, unis, clutch and 2 speed.(whats left huh?) and I think they can be reached easily without disassemblimg too much.
I dont care about anything left(belts, pullies, screws,...)
Mustafa Alp
http://www.aytemizhobi.com
Turkish shop for: Serpent, Xceed, Sweep Racing, MyLaps
musti72 is offline   Reply With Quote
Old 12-01-2009, 11:01 AM   #1563
pulleys are important, I got about 10 grams switching to an older kyosho part with a plastic pulley over the stock aluminium one.
like i said, anything that rotates includes the shafts, pulleys, set screws, cvds, wheel nuts..
I switched some of my 966 pulleys over to aluminium and gained about 9 grams total on the car to have hard coated pulleys but sedan should use plastic.
Old 12-01-2009, 01:03 PM   #1564
crashman1's Avatar
Thumbs down Servo saver
Hi Guys,
Thanks for some great info being shared around, But can anyone tell me if there is a aftermarket servo saver that can be brought as I was running in my car at the race track and just touched the timbers and brock the servo saver, the part with the two holes in it that connects to the steering arms ,Have I done something wrong that it broke so easily, any tips or sugestions welcome.
Thanks Heaps
Jamie
crashman1 is offline   Reply With Quote
Old 12-01-2009, 02:36 PM   #1565
Anyone used this CSO pulley before??
http://www.rc-toro.com/product_info....oducts_id/1902
silverM3 is offline   Reply With Quote
Old 12-01-2009, 02:57 PM   #1566
Android's Avatar
It is no good, it is very heavy, I'm sure it will affect the performance of the car, the original plastic pulleys are better.
Android is offline   Reply With Quote
Old 12-01-2009, 03:26 PM   #1567
Suspended
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
THATS what IM saying its just bling dont get me wrong it looks great
but they need to make some L/W front and rear shafts
comon I bet if we beg they make them
TEAM ARC USA --- TEAM POWERS USA ---- TEAM VALKARIA RC ----
rcpaintinpete is offline   Reply With Quote
Old 12-01-2009, 03:27 PM   #1568
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Regardless of static weight, rotating mass will rob you of power more so than just that weight alone sitting on your chassis.
YR4Dude is offline   Reply With Quote
Old 12-01-2009, 03:39 PM   #1569
Supposedly belt wear with certain belts and certain hardened pulleys is lower and they tend to gunk up the pulley less. CSO believes this if you run all their gear and I have all of their stuff on my 966 and it's ok. The pinions chunk the coating pretty quick though so I would expect the pulleys to have a short life as well but then again they don't take as much abuse. Supposedly the slick coating helps the belt life dramatically.
Old 12-02-2009, 01:19 AM   #1570
Serpent-Dan's Avatar
Default A5
Serpent 733 1/10 200mm touring-img00122.jpg
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 12-02-2009, 03:45 AM   #1571
Julius's Avatar
Although rotating mass is best kept to a minimum, you must not forget that it is a combination of mass and it's distance from the rotation axis. As well as the speed it spins at.
For example getting rid of a few grams inside a hollow mid shaft is way less effective than getting rid of the same weight on the pulley of a diff.
This also holds true with lightweight wheel axles. It will more good because of unspring weight than it will help because of less rotating mass.
This is why the lightweight wheels are so good. They remove unsprung weight but also remove weight at a position far from the rotation axis.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 12-02-2009, 10:19 AM   #1572
serpentamerica's Avatar
Hello guys. The Holiday Season it's here. Check our website for the Holiday Specials
Serpent 733 1/10 200mm touring-500px-xmas_tree_animated.gif
Facebook: http://www.facebook.com/pages/Miami-FL/Serpent-America/120322987992068
www.serpentamerica.com
e-mail: [email protected]
telf: 1-305-677-3253
serpentamerica is offline   Reply With Quote
Old 12-02-2009, 12:40 PM   #1573
Team Kamikaze's Avatar
Special XMAS deals here: http://kamikazetoysandhobbies.com/products.php?cat=64
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 12-03-2009, 03:00 PM   #1574
RC MARKET's Avatar
X'Mas Free Shipping !
http://rcmarket.com.hk/product_info....oducts_id=6728
RC MARKET is offline   Reply With Quote
Old 12-03-2009, 03:33 PM   #1575
Android's Avatar
Shipping for a kit in the US is only $10.00 to $15.00 tops, buy the 733 from a US hobby shop is still cheaper, plus you get better support, 733 kit in the US is only $479.99 plus shipping will still be less than buying it from a Hong Kong hobby shop,
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
