Old 11-27-2009, 01:52 AM   #1546
keavze's Avatar
The 2 speed clutch system is the same as 966? Only the 2 speed shoe is of different p/n? Why the diff in p/n?
Rest of the parts are the same as 966.
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 11-27-2009, 11:18 AM   #1547
serpentamerica's Avatar
The difference is the spring. The 1/8 scale use a stiffer spring than the sedan
Facebook: http://www.facebook.com/pages/Miami-FL/Serpent-America/120322987992068
www.serpentamerica.com
e-mail: [email protected]
telf: 1-305-677-3253
serpentamerica is offline   Reply With Quote
Old 11-27-2009, 10:53 PM   #1548
keavze's Avatar
ok but the 2speed shoe is of different p/n? and both 733 and 966 using same 2speed shoe housing...
Old 11-28-2009, 09:27 PM   #1549
Pattojnr's Avatar
Trader Rating: 19 (100%+)
hi,
what's the best way to 'cure' on power pushing in a sweeper?
anyone tried driving without the front sway bar? thought of removing the front sway bar...
also, what the rear belt tension that you guys set? mine is set at the middle but i've already replace 2 of my rear black belts in less than 10tanks for each belt. front and side black belts still ok though...
Keavze, i tried the spool, no front bar, with purple front springs, i also tried a couple of different tire combos. 37/40 was better than 40/37. 40/37 was good when using the blue front spring, and when the track was a little slippery. i also used the new Xceed A5. the car is close to where i want it now. i ran 1mm caster with the spool as well.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 11-29-2009, 06:36 AM   #1550
keavze's Avatar
thanks paul for yr info...
i'm thinking of trying a softer frt spring (now using blue) with the stock 2.5mm bar. i'm using 37F/40R. 300k frt diff with 80k rear diff. right now my front tires able to maintain the 2mm split from beginning to the end, something not right? usually the rear will wear faster and the split will get lesser right?
won't purple spring be alittle too hard? 1mm caster = how many mm of clips in frt of arms?
so..., spool is better for you than diff?
Old 11-29-2009, 07:12 AM   #1551
Pattojnr's Avatar
firstly i like the spool, i have kept it in to try some things. nothing tried nothing ventured ? by removing the front bar, it actually allows the front wheels to work independantly, by going harder front spring, the car doesnt loose the ability to change direction fast. also i find the harder spring allows for faster weight transfer to the rear, so rear grip actually is increased a little as well. i have 3mm of caster clips in the front of the top arm, with 2mm shorter wheelbase, yes it actually is 1mm of caster. you can run a thicker rear diff oil with this setup as well, due to the increased rear grip. i went from 30k rear to 40k, with short rear wheelbase as well. so i have a car now that rotates well, changes direction quickly and it is very settled.
if you like a car that pushes a little, you can go to 40 all round. i found tire wear to be better with this setup as well. i like this setup, but depends on how you like your car to drive. i can carry more corner entry speed in, and let the spool slow the car down mid corner, then hit the throttle to get around the last little bit. im now getting more front tire wear with this setup, so now my split maintains itself as well. but i must say the grip isnt the best, its actually a low traction track. but i also use the same sort of setup with the 966, a grey front spring and long red at the back.
Serpent - Walter RC
Old 11-29-2009, 12:27 PM   #1552
endy0430's Avatar
Trader Rating: 25 (96%+)
Default Starter Box
guys what starter box are you using for your serpent?
I need a good powerful one cause the one I have is just not cutting it.
endy0430 is offline   Reply With Quote
Old 11-29-2009, 12:37 PM   #1553
RC MARKET's Avatar
I'm used MUGEN
my friend used XRAY smaller size !
RC MARKET is offline   Reply With Quote
Old 11-30-2009, 03:26 AM   #1554
keavze's Avatar
hi paul,
so you didn't use any frt sway bar for both yr 733 and 966?
my 733 is very stable and easy to drive; maybe abit too stable and settled...haha.
my 966 has been pretty dialed for my liking.
Old 11-30-2009, 03:59 AM   #1555
Pattojnr's Avatar
hi paul,
not sure what the tracks are like where you race ? but here is a link to where i race. http://www.onroadrccarclubbunbury.org.au/Site/index.htm
low traction, high tire wear, and piping to make you drive better
Serpent - Walter RC
Old 11-30-2009, 05:42 AM   #1556
keavze's Avatar
you've got the best timings for 1/10 and 1/8... great job!
my track here got similar straight of 55m but 1/8 takes about 17s while 1/10 takes about 19s. low-medium traction, new tires will wear out in about 35-40mins.
Old 11-30-2009, 05:53 AM   #1557
Pattojnr's Avatar
we battle to finish with foam still on the plastic in 30 mins. the serpent wether 720 or 733 seems to have the best tire wear. in official practice for the states, i actually did a 15.9 with the tourer. but its not official time.
Serpent - Walter RC
Old 11-30-2009, 02:51 PM   #1558
Suspended
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
Default DAAAAA
When is sombody gonna make a ti screw kit and some L/W shafts for this car
all i keep seeing is alu this & alu that from cso and a carbon chassie lol
AM I the only person who wants this or what
comon guys how many of you would want these items
this isn't just bling as a racer I feel there is a real need for these
http://www.cso.com.hk/htdocs/index.php this is what they made first
its all nice but bling
WE NEED TI SCREW KITS AND L/W SHAFTS
TEAM ARC USA --- TEAM POWERS USA ---- TEAM VALKARIA RC ----
rcpaintinpete is offline   Reply With Quote
Old 11-30-2009, 05:22 PM   #1559
LW shafts would be cool, hollow steel is good coming from kyosho. ti, maybe not so much..
Ti kit would really be cool, but look for 3racing or someone like that. You could probably get away with the NT1 kit or anything else and be close. Buy 2 for $75 and have plenty of spare ti screws.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 12-01-2009, 07:49 AM   #1560
musti72's Avatar
Is there anyone who can gauge the weight of 733's main and middle shafts, spur gear adaptors, differentials, and universals? Im trying to compare the transmission weights of the cars available today. I have stock and option xray parts' info, and waiting for the capricorn car.
Mustafa Alp
http://www.aytemizhobi.com
Turkish shop for: Serpent, Xceed, Sweep Racing, MyLaps
musti72 is offline   Reply With Quote
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
