Old 11-22-2009, 10:46 PM   #1531
Team Kamikaze's Avatar
That is good to hear that it worked out for you.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 11-23-2009, 01:51 AM   #1532
keavze's Avatar
Originally Posted by Julius View Post
Just try to add some caster. easiest to try and works mostly mid corner and onwards. Thinner front bar will give more steering everywhere but might make the transitions too slow. Other optins are less rear toe, or softer front diff oil.
just to confirm: more caster = top arms more rearwards right?
will try more caster 1st then less rear toe; hate messy oils.
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 11-23-2009, 05:00 AM   #1533
Julius's Avatar
You are right about the caster. Both adjustments are simple and quick to make and change back if it doesn;t work.
Team Serpent, Xceed, Sanwa, LRP
Julius is offline   Reply With Quote
Old 11-23-2009, 06:04 AM   #1534
G87z's Avatar
Originally Posted by GLOWHEAD View Post
Here is my take on the rear belt. The bottom of the belt sits a mere fraction of a millimeter above the bottom of the chassis, almost flush. The 710 had a similar situation with a two tooth larger rear pulley.
If there was a stone anywhere on the track, it would find it's way into my car and wedge itself between the rear pulley and the chassis. When they released the LCG chassis for the 710, it did not have the opening under the rear belt. Problem solved.
My contention is that the rear belt is very vulnerable to contact with debris on the track, or if you clip a berm, or dragging the rear of the car when the tires and ride height get low. All in the pursuit of the lowest CG.
I would much rather have the rear diff sit a millimeter or two higher, and do away with the opening in the chassis. The front belt is similarly placed, but is not as much of an issue as the rear.
The belt on the 720 sits much higher and is virtually protected from contact. A set of belts on my 720 would last me all season.
This is the very thing that will take you out 5 min before the end of your main when you hit somebodies drive dog or shock spring or whatever laying on the track. I'm disappointed that they created this situation again with the 733.
Don't get me wrong, I'm a total Serpent player and am way into this car. I'm just beginning to see a number of post's from guys having rear belt problems.
When you're running a sub A program, like 95% of us out there are, despite what we fool ourselves into thinking, attrition and survivability are at least 50% of the game. I think the rear belt/pulley are just asking for trouble.
Check your rear belt for scratches in the writing, nicks or dents, or dents in the edges of the pulley. If you have them, then you know where they are coming from.
I'd like to give a shout out to my Serpent brethren at 301 Raceway, and all those who traveled to races there. Let's all keep the faith that whatever issues there are will be resolved, and that the 301 facility is reborn for 2010.
Mark Hartzell
Mark,
you made many great points, I can agree that the black belts do no last. I only got one day with my black rear belt. When I switched to the orange belts I have had no problems since. The rear belt has shown no wear. It has had multiple 30 min A-mains and a 45 min a-main. I suppose how well the track has been prepped and what area the track is loacated could make a huge impact with diffrent types of debris.
Team Shepherd USA / Picco Engines / Sanwa / Matrix Tires / Byrons Fuel / SRC
G87z is offline   Reply With Quote
Old 11-24-2009, 01:35 PM   #1535
spurgear's Avatar
Send a message via MSN to spurgear
nice product from xceed rc. A one piece
Serpent 733 trinirc.com
Novarossi Plus 12-3CT Murnan Modified Full Ceramic Edition
Novarossi EFRA 2630 exhaust with medium header
Futaba 3PK HRS with Digital Servos/ JLR Starter Box
East Civic 200mm
spurgear is offline   Reply With Quote
Old 11-24-2009, 02:26 PM   #1536
RC MARKET's Avatar
this week release !
http://rcmarket.com.hk/product_info....oducts_id=7524
shipped !
Serpent 733 1/10 200mm touring-xc-103023.jpg
RC MARKET is offline   Reply With Quote
Old 11-24-2009, 02:27 PM   #1537
RC MARKET's Avatar
Originally Posted by YR4Dude View Post
Okay, I checked my chassis on the board today and despite cranking on the screws in the bulkheads to force the pins in, the chassis didn't tweak. If I had reamed the holes lightly, the chassis would have assembled easily without any complication. I will remember to do that next time.
I do want to say that the hard anodizing did a good job. After a days worth of runs, I took a rag with Nitroclean and wiped the bottom of the chassis clean and saw that the anodize coating is still very much intact. So the plating is good and wears well so far.
isn't anodize !
Old 11-24-2009, 03:01 PM   #1538
YR4Dude's Avatar
Trader Rating: 44 (100%+)
Originally Posted by RC MARKET View Post
isn't anodize !
Then what kind of plating is it?
YR4Dude is offline   Reply With Quote
Old 11-24-2009, 03:08 PM   #1539
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
I need one Sam!
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 11-24-2009, 03:50 PM   #1540
DS Motorsport's Avatar
I think rcmarket means that it isn't the anodizing which causes the holes to be to small.
Anodizing is, in contrary to paint or powder-coating, put into the material instead of on top of it. It only adds a couple of microns to the material.
So it probably has to do with low tolerances, what else can you expect for such a low pricetag?.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 11-25-2009, 08:25 AM   #1541
RC MARKET's Avatar
this is hard coated ,more hard
Sorry ! my english too bad , so unknow how to say it ,
Old 11-25-2009, 08:25 AM   #1542
RC MARKET's Avatar
CSO New Product
7075 T6 ALUM. SUSPENSION FRONT BRACKET L/R FOR 733
Serpent 733 1/10 200mm touring-cso-ser73312.jpg
Old 11-25-2009, 09:21 AM   #1543
Originally Posted by Serpent-Dan View Post
I need one Sam!
Will send you one as soon as I receive it
Old 11-26-2009, 12:40 PM   #1544
Happy Thanksgiving to all my fellow Serpent supporters
Old 11-27-2009, 01:28 AM   #1545
RC MARKET's Avatar
shipped !
RCMC 1/8, 1/10 Gas Singapore National Series round 3, 23 AUG 2009 backplate Singapore R/C Racers 47 08-27-2009 12:03 AM
