Old 06-01-2009, 04:12 PM   #1
didrace's Avatar
Default st-rr axles keep poping out...
Hello to everyone,
i have this problem with my st-rr front axles keep poping out all the time.. i used shims behind the axle i have tried less negative camper but whatever i do the axles keep poping out. i can see the axle to come almost to the outside of the cup when i push the a arm to the top.. this problem started when i used cody king silver state setup where the front arms have more kick up.. the front bushings that are suited on the front tower are on the have the hole above..
if any one could give me any tip that woul be very helful thanks
didrace is offline   Reply With Quote
Old 06-01-2009, 04:38 PM   #2
houston's Avatar
Trader Rating: 91 (100%+)
Originally Posted by didrace View Post
Hello to everyone,
use the 3mm longer ones , i know it sucks but it is what it is
TEAM FUSION X ENGINES /RC-OMG USA/ TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 06-01-2009, 04:46 PM   #3
didrace's Avatar
where can i find them? which are the 3mm longer ones?
Old 06-01-2009, 04:54 PM   #4
didrace's Avatar
my car has the lightweight ones which i think are the longer ones ...are there even longer ones?
Old 06-01-2009, 04:55 PM   #5
houston's Avatar
99% positive there are longer ones but i dont know the part #
Old 06-01-2009, 05:49 PM   #6
freestylinmotox's Avatar
Are you talking about the center driveshafts or the CVD's?
when in doubt, throttle out! braaap!
freestylinmotox is offline   Reply With Quote
Old 06-01-2009, 05:57 PM   #7
houston's Avatar
outers not centers , he is talking about the front universals coming out from up travel .
Old 06-01-2009, 06:03 PM   #8
Ok thanks.
Yea then just do what Houston said. Get the ones that are 3mm longer or change your setup. ride height, hubs, etc.
What mm hubs are you using? I use 22mm and they work pretty dam good!
Old 06-01-2009, 06:15 PM   #9
houston's Avatar
Ok thanks.
you mean 22 degree ?
or put limiters on the outside of the shaft to limit up travel , about 3mm or 4mm plastic spacers between the shock orings and the shock end
Old 06-01-2009, 06:24 PM   #10
haha Yea. 22mm would be pretty dam tiny.
Old 06-01-2009, 06:42 PM   #11
didrace's Avatar
guys is there a way i can find the 3mm longer ones?
Old 06-01-2009, 06:58 PM   #12
rcgeezer's Avatar
I had the same problem to a smaller degree. As Houston recommended, I put a 3mm plastic spacer on the shock shaft to limit the amount of uptravel, problem solved! It doesn't really effect the overall dampering or working of the shock, just at that critical end point which usually isn't reached very much anyway. As long as you have plenty of droop (about 116mm) you'll be fine.
**Team Terribles Northern CA Regional Rep.**
Cold Fusion R/C Products Team Driver
Answer-RC USA / Team Sweep Racing USA
Team RcRenew...visit us at rcrenew.com!
Triton RC Alpha Plus Engines
rcgeezer is offline   Reply With Quote
Old 06-01-2009, 09:24 PM   #13
KIK
KIK's Avatar
Trader Rating: 26 (100%+)
Did you check the king pin bolt on the bottom? Had that happen to me and the bolt threads got striped out of the steering hub on the bottom side. Just gave it enough slop to let the dog bone pop out.
KIK is offline   Reply With Quote
Old 06-02-2009, 12:57 AM   #14
Default HPI RS4 vs Schumacher Fusion 28
Which would you get for parking lot bashing? Does the Fusion have any problems later on? Which is more fun?
pk the d-j is offline   Reply With Quote
