new with rs4and in need of help
hi guys im new to the whole on-road nitro scene and im in need of help and advice,i got myself a rs4 evo3..the car starts well the problem is when you give it gas it slags a bit before taking off but once its moving its luvly..is this normal or is there something wrong...
any help and advice will be appreciated..
if if sluggish when you press the throttle, then is p[roblya bit to rich, lean it out a bit at most half turn on the big needle... do 1/16 or 1/8 turns till its up to your liking ...
thanx guys iv broken the engine in properly ,ill try leaning it in thanx alot
