JLR exhaust seal and spring
hey guys,
i went to my LHS and got a dynamyte exaust seal kit (2 seals one long spring and 3 small springs) this is the second one and i keep blowing the seal... i found an ofna seal that was just round(looked like a small rubber band) and its a much better snug fit than the ones i was useing... the ofna part no. is 51997 and i cant seem to find it anywhere... what other seals could i use?? and whats the spring length to hold the manifold to the engine??(69mm,75,91mm)
and is it a must to run with 2 manifold springs or can i use one if i put one in the top hole and teh other end on the bottom hole?
Kamikaze probably has the OFNA seal. It's the one you want to use.
You can use just one spring but I prefer two for the added reliability.
awsome thanks man, just bought three of them...hahha and some new foams...
