Old 05-26-2009, 12:39 AM   #1
ntc3bionicracer's Avatar
Send a message via ICQ to ntc3bionicracer Send a message via AIM to ntc3bionicracer Send a message via MSN to ntc3bionicracer Send a message via Yahoo to ntc3bionicracer Send a message via Skype™ to ntc3bionicracer
Default jatos brakes
i just broke in a new jato and when finished and started to run fast and wide open after the 5th tank of fuel,,the brakes do not work well at fast speeds they work well at lower speeds they are working correct it seems anyone have any info, is there a better system to replace the stock stuff ???? any info where to purchase
ntc3bionicracer is offline   Reply With Quote
Old 05-26-2009, 10:34 AM   #2
Have you tried adjusting the throttle/brake linkage to give you more braking power or tighening the screws on the brake pads?
Otherwise check towerhobbies for upgrade parts
Kyo83 is offline   Reply With Quote
