-   Nitro On-Road (https://www.rctech.net/forum/nitro-road-3/)
-   -   new with rs4and in need of help (https://www.rctech.net/forum/nitro-road/299511-new-rs4and-need-help.html)
rebel_star 05-24-2009 12:31 PM
hi guys im new to the whole on-road nitro scene and im in need of help and advice,i got myself a rs4 evo3..the car starts well the problem is when you give it gas it slags a bit before taking off but once its moving its luvly..is this normal or is there something wrong...
any help and advice will be appreciated..
Hpimichael 05-24-2009 03:15 PM
if if sluggish when you press the throttle, then is p[roblya bit to rich, lean it out a bit at most half turn on the big needle... do 1/16 or 1/8 turns till its up to your liking ...
KyoshokiddT.D 05-24-2009 03:51 PM
did you break in the engine dont go leaning it out unless the engine is broke in .
rebel_star 05-25-2009 03:25 AM
thanx guys iv broken the engine in properly ,ill try leaning it in thanx alot
Kyo83 05-26-2009 01:33 PM
Originally Posted by rebel_star (Post 5854720)
......ill try leaning it in thanx alot
:DThat would be leaning it out. You turn the needle in to lean the mixture out:D
