Performance question: Under chassis aero package....Is it worth it?
#91
Sedan diffusers
With todays narrow nitro sedan chassis plates, I'm not sure how much good a rear diffuser would do. Most rear diffusers would probably work very well on cars with large chassis plates. Maybe I'm off base here.
#92
You are correct about the chassis plates, but ideal design of a wider chassis would be nice, however with the narrow chassis of today's designs, I addressed that issue to funnel what little air that does go under the chassis directly and make the most of it by giving the diffuser an hour glass shape to create as much vacume as possible.
#93
Interesting to see if you bring your design to market.
Most cars went to narrow chassis designs to limit weight, and to center more of the weight to the center of the car. With Lipo batteries saving almost 60 to 80g's of weight and much lighter drivetrain and suspension parts, it would be interesting to see what a full chassis with aero package would bring to the table. One of the best older handling cars on the mkt was the NTC3. Unfortunately reliability of drive train was always an issue with them. The large chassis plate of the NTC3 probably helped to limit underside aero drag that the current cars possess. The larger chassis plate also helps settle mid-corner aero problems with cross air underneath the car.
#94
Keep it moving! PLEASE
#95
I've been working on some other items and got side-tracked from working more on this.
After a lot of thought, I see no reason to bring this to market for 2 reasons.....first, I don' t have the money to get things started, and second, although I see this as being a good selling item, I don't think that I would make back the money needed to cover the cost of the inital investment within a reasonable amount of time. so....I'm going to be showing you all how to make one of your own rear diffusers. It will take about 30 min to make.
I will post step by step instructions later this week.
#97
hey rcfoolz ! Good thread and idea. I come from electric and my pal and I would like to test your diffuser on our touring cars, your project brought tons of discussions(/debate/fight/murder ;-) on the table . Could you decribe a brief how-to ?
#98
Thank you......
Still waiting for the DO-IT-YOURSELF instructions. jack
#99
my ideas are still in the works on this.....financialy, I don't have the money to invest into making this come to light.....I am holding for a few months, but if somebody wants to take the ball and roll with it, they are more than welcome to call me.
#100
DXF 2wd 1/8 scale with rear diffuser
FYI
Dale
Dale
#102
#104
Thank you......
#105
rcfoolz, did you give up on this? I was thinking of doing something similar myself.
