Old 05-20-2009, 10:56 AM   #1
KinKin's Avatar
Cool Problem with Mamba MAx ESC Please Help & Thanks
I am newbie here. Does some pro help me with this problem? I have a mamba Max with 7700Kv motor. I try the difference pinion gear from 18-26 with 75 teeth spur gear but the ESC still getting hot (around 150-190 degree) if keep play about 15min the Esc will stop running. After cool down will work fine. Is it normal on mamba? Do I need to get a fan for it? Thanks who reply my question.
KinKin is offline   Reply With Quote
Old 05-20-2009, 11:00 AM   #2
chewiefttc4's Avatar
Trader Rating: 26 (96%+)
Send a message via AIM to chewiefttc4 Send a message via Yahoo to chewiefttc4
ok what truck are you running this in? or what car?
what batterys are you using?
we need some details.
chewiefttc4 is offline   Reply With Quote
Old 05-20-2009, 11:51 AM   #3
KinKin's Avatar
Cool
It is a on road Tc4 car and running Orion 3200 lipo.
Old 05-20-2009, 12:27 PM   #4
try a 12 or 13 tooth pinon
Old 05-20-2009, 12:49 PM   #5
KinKin's Avatar
Cool
I canít put small pinion because It doesnít gear up with the spur gear,. Thnaks
Old 05-20-2009, 12:52 PM   #6
corney_01's Avatar
i would also get a fan 4 it as i tried running my speedpassion speedi with out the fan and it got real
Hot put the fan back on and it was fine.
Comen back with..XRAY-KO PROPO- NOVAROSSI
corney_01 is offline   Reply With Quote
Old 05-20-2009, 12:55 PM   #7
KinKin's Avatar
Cool
What happen if I put a bigger spur gear? Will this help. Does anyone explain why Xray make such as large spur gear? Like 112-118 gear what is the advantage of large spur gear. Thanks
Old 05-20-2009, 07:10 PM   #8
KinKin's Avatar
Cool
Thank you everyone on helping. I will updated in later time.
P.S higher gear ratio means.................... Lower SPEED
Old 05-21-2009, 11:10 AM   #9
put on a higher tooth count spurgear...and gear down...the 7700 geared right should sstill yeild 60 mph speeds on 2s lipo.. and it wont thermal..
once you gear too high..your batteries drop voltage and you dont go as fast.. also you heat everything up. whichis whats happening... get a bigger spur.. about 6 teeth if you can. and then try small pinions and work your way up....
Old 05-21-2009, 03:43 PM   #10
KyoshokiddT.D's Avatar
you would have better luck in the electric forum
KyoshokiddT.D is offline   Reply With Quote
