-   Nitro On-Road (https://www.rctech.net/forum/nitro-road-3/)
-   -   manifold problem :( (https://www.rctech.net/forum/nitro-road/297277-manifold-problem.html)
tnez190 05-15-2009 04:15 PM
manifold problem :(
I just recently purchased a THS racing pipe and put it in my stock engine for my Kyosho FW05T- Plus on my first run one of the screws disappeared when cleaning it after 1 tank of fuel.
purchased new set of screws and installed them with new nuts, after one tank and while cleaning it, i noticed the manifold was loose, so i tighten the screws again and the nuts.....
What could be the possible cause of this? should i buy new screws and nuts? should i buy a different manifold?
Thx in advance!
cho~ke 05-15-2009 04:40 PM
LOCKTITE
tnez190 05-15-2009 04:49 PM
Originally Posted by cho~ke (Post 5817608)
LOCKTITE
is that like a thread lock?
aizenbelle 05-15-2009 06:12 PM
http://www.loctiteproducts.com/
let it dry after installing
Renault_Tech 05-15-2009 06:55 PM
LOL good to see im not the only one that had that exact problem with that manifold. No amount of loctite fixed that problem. The nuts would undo themselves and i couldnt finish a 10 min final. Every run i would take the nuts and bolts out, clean with metho, dry, loctite and put the nut on it and it would come loose.
The way i fixed my problem? Got a rear exhaust engine. Never had a problem since.
wizby 05-15-2009 07:44 PM
If you have room doudle nut each screw.
tnez190 05-15-2009 08:28 PM
thanks guys..... guess i should buy another engine :nod:
I've been wanting more power :sneaky:
s10dude 05-16-2009 05:21 AM
the loctite has to dry overnight to be effective....lol
aizenbelle 05-16-2009 07:38 AM
no need to buy a new engine, just let the locktite dry for at least a few hours
tnez190 05-26-2009 10:02 AM
i'll give the locktite a try, and if not then i'll have to just buy a better bigger, faster engine HA HA HA!!!
rageworks 05-26-2009 11:29 AM
Use some locktite and two nuts on each screw. Nothing
worse than having your nuts fall off while your running.
