Old 05-09-2009, 11:56 PM   #1
Ultraspeed84's Avatar
Trader Rating: 45 (100%+)
Default tire trueing
I have a question. how much do u guys take off at a time when cutting the tires? 2 3 4 mm at a time.. because i did it last night only taking 1mm at a time and it took bout 1hr to do a set. how long does it normally take u guys? thanks
yokomo yz-2
Ultraspeed84 is offline   Reply With Quote
Old 05-10-2009, 03:09 AM   #2
Renault_Tech's Avatar
i run a 2mm split and it takes me about 20 seconds per tyre tops.
[KYOSHO] [NOVAROSSI] [TEAM MAGIC G4RS] [O.S SPEED T.Z SPEC II] [SPEKTRUM DX3R]
Renault_Tech is offline   Reply With Quote
Old 05-10-2009, 05:35 AM   #3
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
Comes down to your tire truer motors and your power supply.
Hudy's allow you to regulate the cutting speed.
I cut brand new foams (65mm) down to 61mm in one cut.
Shepherd RC | Brilliant RC | Ielasi Tuned Novarossi | Xtreme Aerodynamics | Matrix |
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 05-10-2009, 06:49 AM   #4
s10dude's Avatar
i will usually take off 2mm at a time for better cut...but if i'm in a hurry...as much as the truer will handle....
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 05-10-2009, 02:22 PM   #5
the tires wont chip and chunk up if u cut alot off at a time?
yokomo yz-2
Old 05-10-2009, 03:59 PM   #6
s10dude's Avatar
sometimes...............depends on bit !
Old 05-11-2009, 02:47 AM   #7
It won't chip if you have a nice sharp bit. I found the Hudy bit is really good as I am the lazy type and alway cut new tires down to 59mm with one pass. With cheaper bit the tire may chip or show an uneven "wave" surface which you need to fix with a hand file. But with the Hudy bit it is a very nice even surface and no hand fixing necessay.
gpm-parts.com is offline   Reply With Quote
Old 05-11-2009, 03:36 PM   #8
solitude127's Avatar
Trader Rating: 21 (100%+)
On my Hudy truer and bit, I've cut my new sedan tires down to 58mm in 1 try. With the Hudy truer, you can control the speed which helps a lot. When cutting that much I go as slow as possible and on the cut on the way back, I speed it up. I trued 2 full sets of sedan tires in about 15 minutes. Like they said in the previous responses, it depends on the truer, bit, and power supply.
solitude127 is offline   Reply With Quote
Old 05-11-2009, 05:00 PM   #9
well i have a hard racing truer and a 20amp power supply. also where can i get replacement blades at?
yokomo yz-2
Old 05-11-2009, 05:12 PM   #10
nitrodude's Avatar
http://www.kamikazetoysandhobbies.co...prod=HUD102067
Right here!
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 05-11-2009, 07:36 PM   #11
will that blade work on all tire truers?
yokomo yz-2
Old 05-11-2009, 08:33 PM   #12
JetMD's Avatar
No, not all. It's made for a Hudy truer but it can be modified to fit some other truers. Don't know about all though. For mine, I have an Integy truer and it's made for saw blades which are very thin. That bit is too thick to fit into my truer. So, if I got one, i'd have to use a dremel or something like that, to make the bit thinner to fit my truer. Lucky for me, I found someone that makes a thin blade like that which fits my truer perfectly. Not sure about your truer though. Hope that helps.
www.vorra.org
MINO Racing
JetMD is offline   Reply With Quote
Old 05-12-2009, 06:19 AM   #13
GREGORY!'s Avatar
ultraspped84.
take a look in the link.you will find him!
http://www.rctech.net/forum/nitro-ro...ybody-try.html
GREGORY! is offline   Reply With Quote
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
Mugen MTX-3 university_dave Nitro On-Road 17237 12-30-2012 01:16 PM
What's left for ROAR to conquer? or8ital Electric On-Road 61 01-18-2008 10:50 AM
Rubber Tire touring car racing... Nexus Electric On-Road 183 06-18-2006 08:41 PM
Serpent 710 chat crashed_1 Malaysian R/C Racers 1498 05-17-2006 07:54 PM
For Sale Team AUTOTRUECUT Tire Truing Machine dakilo R/C Items: For Sale/Trade 7 05-04-2006 09:05 PM
