inferno gt gearing/change suspension set up >
Old 05-07-2009, 05:39 AM
Post inferno gt gearing/change suspension set up
I would like to increase the top speed of my inferno gt and understand that the new inferno gt-2 gears can be installed. What's confusing to me is I've read that along with replacing the 2 spur gears to 40 and 46 tooth,it's necessary to replace 1 pinion gear to 21 teeth.Would'nt I also have to replace the 2nd pinion gear in order for the gears to mesh properly? I also would like to adjust the suspension but the only tool I've been seen so far is from Hudy and is expensive. Any help is much appreciated.
quattro61 is offline
Old 05-07-2009, 07:28 AM
rpespo's Avatar
There is more detailed info regarding IGT gearing at...
http://infernogt.proboards.com/index.cgi?
In regards to the suspension, set-up stations are expensive. The Hudy is expensive but very well made. I think Integy sells one that is a little cheaper. Have you added adjustable turnbuckles? They are a must for making adjustments. I pretty much eyeball mine, making sure I make equal adjustments to both sides.
If your interested, there is a group of us that run IGT's at the Ronkonkoma train station on Sundays. This week, will will try to get together on Saturday. You're more than welcome to come down and run.
Rich
rpespo is offline
Old 05-08-2009, 12:21 PM
Default thanks for info
Rich
Thanks for info with web site and susp set up gauge. Can't make it to the train station this saturday but the following week on Sunday should be ok weather permitting.
Rich
Old 05-08-2009, 02:27 PM
rpespo's Avatar
Rich
Rich
No problem, we are usually there on Sunday's after 10am in the southwest corner of the lot, if the weather is good. Just show up and introduce yourself.
rpespo is offline
