Setup for driving in rain >
Old 05-05-2009, 05:08 PM
Default Setup for driving in rain
Hi everybody,
first, i want to say sorry for my bad english.
At the next weekend, i will attend a race and the weather seems to get bad (->windy and rainy). So, now i want to ask you guys how to setup my Xray NT1.
I will use rain tires. They are made of durex and they have a profile (i hope you know what I mean)
I adjusted the front toe to 1(out) and the rear toe to 1.5 (in). In front, the camber is 0.5 and 0.25 on the rear wheels.
I also detached the rear anti-roll bar and i setted up my shock absorbers that they will work more softly.
What remains to be done?
Thanks for your help.
FromGermany is offline
Old 05-05-2009, 09:43 PM
Taylorm's Avatar
Originally Posted by FromGermany View Post
Hi everybody,
.in the US we go in when it rains.......
Taylorm is offline
Old 05-05-2009, 10:24 PM
Balloon for you receiver
TOUBS is offline
Old 05-06-2009, 08:13 AM
Yeah...you guys in Europe are hard-core. We don't race much in the rain unless it starts after we started, however some place will still quit depending on how hard its raining.
With that said, make sure to cover up you electronics. I think just changing your driving lines will help alot too.
Kyo83 is offline
Old 05-06-2009, 11:27 AM
Roelof's Avatar
Use some cleaning putty to seal the balloon, it works for sure !
Also use a 2nd ballon to be sure the 1st one will not get damaged.
Do not use an airfilter! If you are using an INSBOX just cut off the foamfilter so it can not run full with water and block the airflow.
In hard rain it is wise to be sure to keep temperature in the engine, place a sheet of lexan between the chassis and motormount so the chassis will not cool down the engine. Also use a smaller head or even some do not use a head. This head is from an airplane
I do not change a lot on the car, creating more roll by taking away the swaybar can mess up the performance of the car, the only thing I do is minimise the camber and loosen the srews which adjust the play on the rear swaybar. The extra play will give a small roll into the car but the swaybar will pick it up when the roll goes to far.
And when you have aqua's it is time to play !!!!
http://www.youtube.com/watch?v=6_ZSr4FFvOM
Roelof is offline
Old 05-06-2009, 02:28 PM
Nice drifts Roelof especially considering the type of car you're doing it with. I wish I could have seen that in person
Kyo83 is offline
Old 05-07-2009, 08:47 AM
Hi,
thank you guys for your answers. I have already proofed the electrik against water. This is not my problem. I only want to know how you setup your cars (chassis).
I will test the adjustments and I will tell you after the race, how good it worked.
Thank you for your help.
