Old 12-15-2003, 11:07 AM   #1
Send a message via AIM to Profoxcg
Default Recomended servos for gas car?
Can someone point me in the right direction? I am shopping for servos for my gas car and also a small receiver
thanks !
Profoxcg is offline   Reply With Quote
Old 12-15-2003, 11:24 AM   #2
InitialD's Avatar
Default Re: Recomended servos for gas car?
The smallest and lightest receiver I've seen is from KO. I may be wrong but I believe the KO Helios has the smallest receiver in it's class.
Servos? High torque for throttle / brake and high speed for steering.
Digital servos are nice but not so for throttle / brake service and they tend to fail more easily there. Perhaps nearer to the engine vibrations. Not forgetting digital servos drain more power.
Digital servos are more accurate and have better holding power and centers better. Hence, they are better used for steering. For throttle, analog servos are better.
If it was me, go with KO 2343 (or 2143) digital servo (0.08 sec, 8 kg) for steering and KO 2174 analog servo (0.13 sec, 12 kg) for throttle / brake. My 2 cents.
Old 12-15-2003, 12:05 PM   #3
thanks !
what about futaba? I have a 3pk .. .are they not good?
Old 12-15-2003, 12:21 PM   #4
Francis M.'s Avatar
i run the ko 2143 for the steering and 2174 for the throttle and
have been more than happy with performance and reliability of
the servo. ive had 1 servo fail in the past 2years of busy racing
and got my servo back 2 1/2 weeks back from the time i sent it
to ko.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 12-15-2003, 03:54 PM   #5
Corse-R's Avatar
Futabas....
What you really need is metal gears and bearings on your servos. Digital servo for the steering and analog for the Th/Brake. Mine choose like many others go for a combo of Futaba 9450 on the steering and a 9402 on the throttle.
Have many Futaba units with more than 3 years of services and hadn't missed a beat during this three years. In fact until two months ago where I totalled mine MRX3, the servo that was destined as a spare part remained on their original packages (well, the green carton was a little less green and probably more black. )
Just remember that KO units are Fet servos that need separate power and this complicates a little more your electrical installation. Just KISS and go with servos that doesn't need separate power lines.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 12-15-2003, 04:15 PM   #6
Francis M.'s Avatar
Just remember that KO units are Fet servos that need separate power and this complicates a little more your electrical installation. Just KISS and go with servos that doesn't need separate power lines. [/B][/QUOTE]
i don't know what your talking about by my ko is a direct plug in
to the receiver with the power source receiver pack pluged into
to the receiver. that is standard wiring for nitro
Old 12-15-2003, 07:34 PM   #7
Manticore's Avatar
R/C Tech Charter Subscriber
to the receiver. that is standard wiring for nitro [/B][/QUOTE]
the older version of KO fet servo are 7.2 volt and it requires a seperate wire to get 7.2volt input.
Manticore is offline   Reply With Quote
Old 12-15-2003, 08:23 PM   #8
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
To my knowledge KO only made one 7.2v servo. I believe it was the 2142. The 2173, "74, "43, "44 are all 6v servos with conventional plugs exactly like the Futabas.
Racing4Evo is offline   Reply With Quote
Old 12-16-2003, 05:10 AM   #9
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
I think the lastest HITEC servos are good.
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 12-16-2003, 07:22 AM   #10
Pyramid's Avatar
Since you are having 3Pks.. Futaba S9451 (also comes in the standard radio set package) is more than good enough for both 1/10 and 1/8 on road. S9550 always been my first choice for 1/10GP. It is much stronger than it looks.
Pyramid is offline   Reply With Quote
Old 12-16-2003, 09:52 AM   #11
i didnt get any servos with my radio, just the receiver
Old 12-16-2003, 10:01 AM   #12
InitialD's Avatar
I actually forgot to mention what type of receiver did you get? HRS or PCM?
With HRS, there is no way you can use analog type servos. Don't try it as you'll fry the analog servos with the HRS receiver. So you only can use digital servos only.
With PCM, then you can mix and match any digital or analog servos.
Old 12-16-2003, 11:52 AM   #13
good, because I have the PCM.. cool !
thank you for you help guys !
recomended motor for e-savage mitchellmoxon Electric Off-Road 0 03-25-2007 09:28 AM
PD2 Great seller highly recomended crazymechmow Buyer/Seller dispute and Feedback discussion forum 1 01-19-2006 04:41 PM
Recomended first car..... Offroad Impreza SKT Australian Racing 3 01-06-2006 03:55 AM
JasonC - Great Seller! Recomended!! BritRacer Buyer/Seller dispute and Feedback discussion forum 0 02-11-2005 11:13 AM
Recomended Power Supply pro4x Electric On-Road 12 03-13-2004 09:50 PM
