Old 09-03-2009, 04:30 PM   #121
Leichtmetall's Avatar
Originally Posted by gpm-parts.com View Post
Nice fast track. ............ Have fun with your Edam.
Fast?
I think, it is a very low speed track in Köditz. Shortest Gears, only 2 short time in second gear. The straigt is ~30m. The length is 230m and the fastest lap i think it was in 12 Seconds by Michael Heinrich.
First i tried green Springs from Kit (1,9mm, purple Edam is 1,7mm)), heavy understeer with kit-setup. I make front small to 252mm, tried toe in and toe out. The anti-roll-bar is flat (smooth) The rear antir-roll-bar is totaly hard. For tyres i use 32 shore in front, 35 in rear, sometimes 37 in rear.(I use GRP tyres, because we can´t get here much more Tires on OS1 Rim) This is nice, if the temperature is more than 20°C. Under this temperature, the car is understeering, don´t ask me why Tire difference is 6-9mm.
Bevore the 25W Serpent Oil in front, i used a harder Oil. The car was quick in direction-changing, but in corner... understeering.
I think, at your location, the Temperatures will be much time higher than here in Germany.
But, i have fun with the car and i hope to get the Jump in Main-Final at Final for german Hobby-cup with the Novarossi N21 5T Engine.
Thanks again
LM
Leichtmetall is offline   Reply With Quote
Old 09-03-2009, 09:20 PM   #122
Sorry it look much bigger in the picture and I through the straight is like 50M+. Our track we are running 17's and average 18's per lap. If the track is not fast I think 1.7 spring should be ok. Maybe you can try to set the ride height higher to help with the bottom out issue. Good luck with your race!
http://www.gpm-parts.com
gpm-parts.com is offline   Reply With Quote
Old 11-11-2009, 07:28 PM   #123
TeamPursuit's Avatar
Send a message via MSN to TeamPursuit
Mr Marcos Mayer Win gain in Sao Paulo Brazil with Pursuit SPT1
and Mr Luiz Finish in 5th with Pursuit SPT1 this car is an Champion we see it in Houston 2010 WC
TeamPursuit is offline   Reply With Quote
Old 11-11-2009, 08:20 PM   #124
Luiz PM me please
Old 02-07-2010, 02:32 AM   #125
Bundy_Bear's Avatar
Hi
I have completed my Pursuit SPT1 today... Just wanted to thank Terry for his great service and look forward to hitting track soon!
Andrew
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 02-07-2010, 02:37 AM   #126
Originally Posted by Bundy_Bear View Post
Hi
Andrew
Hi Andrew,
Does the SPT1 use the same 2 speed as the Spirit ? also does the kit come with a diff in the front or the standard locker/oneway ?
Cheers Michael
Mike 78 is offline   Reply With Quote
Old 02-07-2010, 03:41 AM   #127
Bundy_Bear's Avatar
Originally Posted by Mike 78 View Post
Hi Andrew,
Cheers Michael
Hi Michael
It comes with a front gear diff... by all looks the 2 speed is the same. Terry should be able to confirm though!
Hope the weather clears so i can have a run next weekend!
Andrew
MissMooRC Racing
Old 02-07-2010, 01:26 PM   #128
Hi Michael
Andrew
it will be good to see how the front diff goes i was thinking about getting to give the car a bit more steering on turn in.
lets not talk about the weather it hasn't stopped raining in sydney for a week and we missed out on racing at moorebank yesterday. anyway i'm interested to hear your feedback on the spt1.
Cheers Michael
Old 02-13-2010, 12:07 AM   #129
Bundy_Bear's Avatar
Hi
Well i tried to run my SPT1 for the first time tis arvo... After a minute or so my engine stalled, while i was trying to refire it on the starter box it threw a clutch weight out from the clutch bell!
Did i not assemble something correct for this to happen? I followed the manual as best i could!
Thanks in advance
Andrew
Edit: On closer inspection the screw that holds the clutch bell has come loose... Don't know why this would be though!
MissMooRC Racing
Old 02-13-2010, 02:25 AM   #130
Hi
Thanks in advance
Andrew
hey Bundy this is why you must sell them partially built and not run them !!!!!!! LOL
anyway better luck next time
Old 02-13-2010, 02:40 AM   #131
Bundy_Bear's Avatar
Not sure i would buy one of my cars if this is how they are built! So would you say it is user error?
MissMooRC Racing
Old 02-13-2010, 03:29 AM   #132
hey andrew only stirring (stick to building just the front ends of the car much safer LOL) but in all honesty i have never had the clutch bell on any of my engines ever come loose (watch what happens next meet) i do check them after each run but............ strange
Old 02-13-2010, 06:13 PM   #133
Bundy_Bear's Avatar
Mike: It's all good... i have it all back together thanks to my spares I used some loctite on the screw and also reset the starter box in case it was rubbing on the clutch bell. See how i go today!
MissMooRC Racing
Old 02-14-2010, 01:42 AM   #134
Bundy_Bear's Avatar
Update: I ran the car again today... I didn't have more issues with the clutch. But i can't seem to get the 2 speed to change at all. I backed screws in the 2 speed to no avail, my engine will also flame out at about 2 minutes.
It's got me beat, i have a feeling engine issues are due to 2 speed!
MissMooRC Racing
Old 02-14-2010, 08:06 PM   #135
aespoleta's Avatar
friends, Terry is to be congratulated on their work and admire greatly SPT1
friend terry hope you here in March at the first stage of Pernambucano,brazil
aespoleta is offline   Reply With Quote
