Old 05-10-2009, 08:24 PM   #31
TeamPursuit's Avatar
Send a message via MSN to TeamPursuit
Hey all if you want to take a looking on the new Pursuit SPT1 we will be on Kamikaze race this came weekand at Cristal Park
TeamPursuit is offline   Reply With Quote
Old 05-12-2009, 01:58 PM   #32
Hi All Where is all the SVM Drivers???
Old 05-12-2009, 04:03 PM   #33
Trader Rating: 293 (100%+)
Terry,
What date are you arriving for the Capitol Classic?
rcdoktor2 is offline   Reply With Quote
Old 05-12-2009, 04:07 PM   #34
Bundy_Bear's Avatar
To setup front overdrive, do you use the 23t or the 24t side pulley?
Thanks in advance!
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 05-13-2009, 08:40 AM   #35
Originally Posted by rcdoktor2 View Post
Terry,
On may 20th i will be there
Old 05-13-2009, 08:41 AM   #36
Thanks in advance!
BB
23 it's better
Old 05-13-2009, 03:49 PM   #37
Bundy_Bear's Avatar
Originally Posted by TeamPursuit View Post
23 it's better
Thanks... Any tips for the shocks? They are very tight, i have tried to open the plastic washers up with the dremel, but it hasn't worked the way i had hoped.
Thanks in advance
BB
MissMooRC Racing
Old 05-13-2009, 05:07 PM   #38
Thanks in advance
BB
where did you buy it
the chocks came on the first model was defected I just made a new O-ring and it's perfect now
Old 05-13-2009, 08:23 PM   #39
Terry,
We will be there on May 15
Old 05-13-2009, 08:28 PM   #40
Originally Posted by MAXX_BASHER View Post
hi all
i have a question regarding the bearing excentrics in the rear hubs. the book suggests to use the neutral ones but what i would like to know is what i can expect to gain or loose by using the offset ones in each direction. i.e forward or back, up or down.
thanks in advance for any help with this
Ok if you move the axel forward it will give you more dogbone sweep and it should have more forward traction, up or down will change the rollcenter like moving the rear lower pin up or down, so its good for fine tuning.
Old 05-13-2009, 08:30 PM   #41
back will make the car longer, maybe good for more stability, I have to test more only ran the car at one race in Brazil so far, but it was very good. C.T.
Old 05-13-2009, 08:33 PM   #42
for me if you have the first tight shocks you can take out 1 o-ring and put in a plastic spacer in place of the o-ring.
Old 05-14-2009, 01:52 AM   #43
Bundy_Bear's Avatar
I got it in Hong Kong...I will have to see if something from a different brand car will fit.
I also had to remove some material off the bulkhead as the steering rack was rubbing a little!
BB
MissMooRC Racing
Old 05-14-2009, 03:29 PM   #44
MAXX_BASHER's Avatar
Thanks for the info. ill try a few things and we will see how we go.
thaks again
MAXX_BASHER is offline   Reply With Quote
Old 05-17-2009, 07:58 PM   #45
no problem we are here to help anyone
After finish the Kamikaze race the new Pursuit SPT1 made to de podium Chris Tosolini after lost the antena Tube finish in 3rd place the car was fest!!!!!!
