Old 04-24-2009, 02:45 PM   #1
Default need help with my dam rc car
when i start my car it starts but when i take out my Glow Plug it turns off. so what can i do so it will stay on
neres818 is offline   Reply With Quote
Old 04-24-2009, 03:12 PM   #2
porkey's Avatar
That is going to happen when your your car Is running and you try to take out the glow plug. Your piston is no getting any compresson so there for it will stall. You should know that.
AE T4: 8.5 AE B4: 10.5 AE B44: 7.5
www.michianabuildingsupplies.com(Sponsor)
www.embassyrcraceway.com
www.michianarc.com
www.steelmx.com(Sponsor)
porkey is offline   Reply With Quote
Old 04-24-2009, 03:21 PM   #3
fastharry™'s Avatar
Location: Mahwah, NJ.. USA!! ..... Home of http://www.fastharry.com
Send a message via Skype™ to fastharry™
You're talking about the ignitor, not the actual glo plug, right?..
www.fastharry.com---search "fastharry" on facebook
See Fastharry in Super Nitro racing at the HPI CHALLENGE...
http://www.youtube.com/watch?v=jzo-cBEnE0c
fastharry™ is offline   Reply With Quote
Old 04-24-2009, 03:39 PM   #4
I believe you're right there, Fastharry. With that said, neres818....once you get it started, leave the glowplug ignitor on your vehicle and either hold your car in place while you give it a little throttle or pick it it up and give it jab or two of acceleration from the radio. This will help clear out some of the excess fuel that sometimes builds up when starting engines. After that take the glowplug ignitor off and see if runs or still shuts down. If it shuts. If its still shuts down turn youy high speed needle a 1/8 of a turn clockwise to lean it out a bit. Also check to make sure you don't have a leak in gas/exhaust lines and fuel tank.
BTW...is this a new car/engine?
Kyo83 is offline   Reply With Quote
Old 04-24-2009, 03:44 PM   #5
no bro it is not a new one it is a nova .12
Old 04-24-2009, 03:47 PM   #6
but when i give it some throttle it turns off as well bro
Old 04-24-2009, 03:50 PM   #7
So...you're saying even with the glowplug ignitor still on the car, it shuts down when you give it gas on the throttle?
Old 04-24-2009, 04:02 PM   #8
kmh
I would start with a new plug. Then once it starts, I would adj. the IDLE SCREW to keep it going and then tune from there. Sounds like the idle is out of adj or it is to rich on the top.
kmh is offline   Reply With Quote
Old 04-24-2009, 04:48 PM   #9
05tuonojoe's Avatar
ya bro.
05tuonojoe is offline   Reply With Quote
Old 04-24-2009, 04:48 PM   #10
ziggy12345's Avatar
Change the plug.. End of.. Close the thread
Dedicated RC Car Speed Site
http://www.fast-rc.co.uk/forum/index.php
Sponsored by:
Norfolk and Chance
ziggy12345 is offline   Reply With Quote
Old 04-24-2009, 05:01 PM   #11
RickBac's Avatar
Trader Rating: 20 (100%+)
Ok, if you are still having problems, reset the carb settings to factory. Put in a new glow plug. Make sure the Glow igniter is fully charged. Set the idle screw so it is barely open, about 1mm.
Start the engine. Leave the igniter attached to the glow plug. give the trottle some burbs. If it dies restart it. Lean out high speed needle a little and try again. Once the engine is at running temp take off igniter and it should run fine. adjust needles as needed.
One other place to look is the clutch. Clean it up. It may be worn out and/or engaging way to early causing the engine to die.
Losi XXX-CR
LRP Sphere Brushless
HB D8
Trinity .21
Airtronics
RickBac is offline   Reply With Quote
Old 04-24-2009, 05:16 PM   #12
SammyZ's Avatar
Trader Rating: 138 (100%+)
that darn r/c car
Hotbodies USA
SweepRacing USA
SammyZ is offline   Reply With Quote
Old 04-24-2009, 06:17 PM   #13
rpespo's Avatar
Get an OS #8 plug and invest in a set of Mechanix gloves. For $25 you get a good set of gloves will make the pullstart bearable not to mention come in handy during marshalling.
Rich E
Inferno GT1 / LRP Z.28R / Ipanema 2-speed / Dragon Racing / Max Velocity
Monster GT / LRP ZR.30
Spektrum DX3R
rpespo is offline   Reply With Quote
Old 04-24-2009, 06:41 PM   #14
wingracer's Avatar
Trader Rating: 24 (100%+)
Listen to this man, do as he says.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 04-24-2009, 08:25 PM   #15
Trader Rating: 21 (100%+)
I second that.
VA_Racer is offline   Reply With Quote
Losi 8ight building and setup JBRacing Nitro Off-Road 8691 06-27-2011 09:43 AM
Trains and Lanes Onroad Racing Summer 08 edition t_laible Racing Forum 2280 06-09-2010 02:41 PM
Outdoor rc Vancouver/Richmond BC fasteddie d Canadian R/C Scene 130 11-02-2009 01:37 AM
I want out. sokar Nitro Off-Road 80 07-10-2009 05:37 PM
FOR THE NEWBIES!!! IF YOU ARE NEW READ THIS omaharich Electric On-Road 54 01-18-2007 02:32 PM
