Old 04-29-2009, 06:08 AM   #16
Maximo's Avatar
Originally Posted by vinrx7 View Post
Thats the whole problem. Cant lower the engine closer to the chassis. Its already as low as it will go. The bottom of crankcase is already just about touching the chassis.
No worries though, i ran 4 tanks through the enginie and it starts up alot easier now. Big difference.
the LHS that told you that you need a new motor obviously isn't very astute.... You need to get a larger diameter flywheel ! the RTR flywheel is likely too small of a diameter... A Force 28 can easily be bumpstarted in a DM-1 !
Maximo is offline   Reply With Quote
Old 04-29-2009, 08:19 AM   #17
Foxxrocket's Avatar
True that. A $300 engine or a $20 flywheel.
Tamiya 416X/ Tamiya TA-05 IFS/ Losi XXX-SCT/ HPI Baja 5SC/ Tamiya M05/ Tamiya F103/ Tamiya F104/ Team Associated 10R5O/ Kyosho IGT2/
Foxxrocket is offline   Reply With Quote
Old 04-29-2009, 09:21 AM   #18
Originally Posted by Foxxrocket View Post
Did you try using a Kyosho multi starter? It has a much smaller wheel.
Yeah...I bought that bump box back in December and it has been great for all my nitro vehicles. Because of small wheel it has more torque too. I love it
Kyo83 is offline   Reply With Quote
Old 04-29-2009, 08:09 PM   #19
I havent seen the kyosho box. I might just buy the Ofna box. I hope it works without having to change my flywheel. Its advertised for the DM1.
I figured the guys at the hobby shops i went to must not have known what they were talking about or were just trying to get me to buy a new motor. I thought maybe changing the flywheel or getting a box that has the wheel pushed up higher above the platform would work.
Anyhow, thanks for the help guys!
vinrx7 is offline   Reply With Quote
Old 04-30-2009, 08:51 AM   #20
CurveTracer's Avatar
Both flywheels that I use are 34 mm in diameter. The engine mounts are about 14 mm high in my DM1 Spec (STS .28 engine) and Kyosho (Force .28 engine) cars.
I am using the Ofna Chrome Top starter box with a 12v. gel cell battery.
Hope this info helps you get setup.
"Yellow Jacket" Mugen MTX-6, Picco Torque
TeamNITRO RC Club, Lynwood, Illinois
CurveTracer is offline   Reply With Quote
