Old 04-19-2009, 04:30 PM   #1
kwilke's Avatar
Trader Rating: 172 (100%+)
Send a message via AIM to kwilke
Default Whats the difference in tire truers brand wise
Is the hudy that much better than anythingelse ?there is alot of different brands and prices.
Bluegrass Hobbies
www.bluegrasshobbies.com.
kwilke is offline   Reply With Quote
Old 04-19-2009, 05:04 PM   #2
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to rezenclowd3
It mainly comes down to the bit used, and the motor. The Integy motor is too small, so it takes longer to make a deep cut, and the bits wear quicker than the carbide bits. However, other truers can use carbide bits from GQ and Hudy.
The Hudy will cut pretty deep into even the hardest foams without slowing much, then come back for the auto return to get the perfect surface cut.
I figured its most likely a once in a lifetime purchase, so I bought the Hudy Auto. IF I sell it, the Hudy retains its value much better than the cheaper ones as well.
OOMSGFX.COM (no longer painting, but take a look for fun!), Roadrunners RC Club
"Racing drivers have balls, unfortunately, none of them are crystal" (David Coulthard)
"I believe the average IQ of a NASCAR fan is only marginally above the things that hit the windscreen during the race. "
rezenclowd3 is offline   Reply With Quote
Old 04-19-2009, 08:01 PM   #3
lil-bump's Avatar
Trader Rating: 83 (100%+)
I agree the Integy is well under powered. For the price of the GQ your better off getting the Hudy. I opted for the Ofna. Very strong motor, and it accepts a hudy bit. The only grip is with the Hudy bit the gauge dial is off by 2mm. I did some machining to my bit holder. Now it's as accurate as a Hudy. Out the box; nothing beats a HUDY. It's just a matter how deep your pockets are.
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 04-19-2009, 09:09 PM   #4
spurgear's Avatar
Send a message via MSN to spurgear
From what i have read on this forum it seems the Hudy's motor is far superior in performance. So i guess that is what makes for reliability as well. I was told these things are heavy!
Serpent 733 trinirc.com
Novarossi Plus 12-3CT Murnan Modified Full Ceramic Edition
Novarossi EFRA 2630 exhaust with medium header
Futaba 3PK HRS with Digital Servos/ JLR Starter Box
East Civic 200mm
spurgear is offline   Reply With Quote
Old 04-19-2009, 10:05 PM   #5
shesha's Avatar
Send a message via MSN to shesha
We are using the GQ tire truer here at the shop, and we go through alot of tires.
In terms of power, they will go through 2MM without a drop in performance as long as your power supply has high amps to feed the truer. Look at a power supply in the range of 20 to 25amps.
The adjustment cutter knob is a bit of, so it needs calibration.
Hudy is Hudy there is nothing out there in that category but for the price i would get 2 GQ's.
R.C.C.C.K - Team Kuwait
shesha is offline   Reply With Quote
Old 04-20-2009, 05:02 AM   #6
freestyles's Avatar
Trader Rating: 14 (100%+)
The difference is about $500 They all cut a tyre
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 04-20-2009, 05:51 AM   #7
iphoone's Avatar
I would prefer my 3racing which is cheap and good. So far No problem with it. Just change the blade to hudy and most of the problem solved.
iphoone is offline   Reply With Quote
Old 04-20-2009, 06:52 AM   #8
s10dude's Avatar
i like my Eagle Racing Scorpion (Integy ).....w/hudy bit....lol
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 04-20-2009, 07:38 AM   #9
DS Motorsport's Avatar
The only option is a hudy if you ask me, nothing gets close in performance and quality. With the 3racing one you really need to run in your tire's. It doesn't give a perfect cut like the hudy one.
Plus the hudy will outlast everything else, and has a good resale value.
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 04-20-2009, 07:44 AM   #10
wwoodruff
Guest
Posts: n/a
Maxmod, it will probably last longer than me. Buy the Hudy, everything else is made in China.
Old 04-20-2009, 09:18 AM   #11
breez1090's Avatar
I HAVE THE OFNA MANUAL TIRE TRUER AND I WANTED TO KNOW IF THE HUDY CUTTING BIT WILL FIT ON IT
I THOUGHT THE OFNA ONE WORKED FINE TILL I USED ONE OF MY BUDDIES HUDY TIRE TRUER THE TIRE LOOKED WAY MORE SMOOTH AFTER THE CUT ON THE HUDY AND YOU GUYS ARE RIGHT ABOUT THE PERFORMANCE ON THE MOTOR
Dwayne Island breeze II
Xray NT1 Xray T3
360 2.0
breez1090 is offline   Reply With Quote
Old 04-20-2009, 09:27 AM   #12
Team Kamikaze's Avatar
Yes, the HUDY carbide cutter fits the OFNA truer without a problem.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 04-20-2009, 09:31 AM   #13
breez1090's Avatar
THANKS
Xray NT1 Xray T3
360 2.0
Old 04-20-2009, 10:11 AM   #14
lil-bump's Avatar
Do you stock the (new)Ofna truer with the square blade holder ( the scale is more designed like the hudy)
Elliott Hart
Serpent America
Desoto Racing Team
Old 04-20-2009, 10:31 AM   #15
The Automatic Truer or the Manual Truer?
