mtx3 rear diff??????
Can I tighten my rear diff? The left wheel unloads or doesn't spin all the time and it handle weird. What can I do to fix this. Im doing this tonight so help me soon if you can. Thanks.
you could always just run a solid rear axle....
Thanks for all the help I swaped my good rear end for the new cars crappy one. After hitting a curb head on at 50+mph my trusty tz fired up second bump on the box!!!!
Make sure that the four o-rings and washers on/in the four small spider gears are in tacked. Also check the o-ring and washers for the out drives are good.
If your running on a track 30,000 is the starting point. If your running a un-prepared parking lot you might need something softer?
