Old 12-10-2003, 12:10 AM   #16
Que
Now that's funny
Que is offline   Reply With Quote
Old 12-10-2003, 12:37 PM   #17
stefan's Avatar
Send a message via AIM to stefan
Originally posted by Fisher890
Hey stephan have I once mentioned your name or refered to you in this thread?Being that you are a mere mortal you sure do act omnipotent. If you truely are omnipotent you would know what I was saying to Dino as it was actually referring to a PM that we have been discussing. Dino is indeed a Very good Motorman and he has been helping me with something in particular.However as always you don't have all the facts nor even 1 answer just Diarrea of the Keyboard. Do yourself a Favor and go try to impress someone else because all you are doing is making yourself look stupid by following me around and trying to make me out as some know it all idiot I'm always the first to say that I am fairly new to Nitro R/C. Sorry dino if this taints the spirit in which this useful bit of advise was posted.
P.S. Venom Temp Gauge is Still working Great! I Think you have a fever Stephan why don't you take a body Cavity temp with your Tempgun?
Why don't you go and screw yourself Punk?
stefan is offline   Reply With Quote
Old 12-11-2003, 01:35 AM   #18
Fisher890's Avatar
The Defence rests your Honor.............
Fisher890 is offline   Reply With Quote
Old 12-11-2003, 07:55 AM   #19
Default Re: A quick check on your engine bearing.
Originally posted by dino.tw
........ If this is the case, the bearing has worn down. A badly worn bearing may release a lot of metal debris which is harmful to your engine to the piston/sleeve and combustion chamber.
and how can I remove the bearings inside the engine if this is the case of my engine?
penggoy is offline   Reply With Quote
Old 12-11-2003, 04:43 PM   #20
EVOLUTION's Avatar
Default Re: Re: A quick check on your engine bearing.
http://www.rbproducts.com/rbww/faqrb...gebearings.htm
EVOLUTION is offline   Reply With Quote
Old 12-11-2003, 04:51 PM   #21
Motorman's Avatar
good tip,
this happens more than you think and causes serious overheating issues as the crank starts to rub the case bore. It also kills low end torque as it pushes the crank away from the critical sealing window on the intake side
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 12-12-2003, 08:53 AM   #22
Nitro Tech
dino.tw's Avatar
Smile
dino.tw is offline   Reply With Quote
Old 12-12-2003, 03:22 PM   #23
fmolzer's Avatar
wow hot in here ! I like the tip though. Let's keep the thread clean and use PM for bashing each other.... Just a thought...
fmolzer is offline   Reply With Quote
Old 12-13-2003, 01:47 PM   #24
While I was assemling my clutch I found that the rubber shield of my engine has fallen off. Is this common and can dirt come through the bearing and ruin the engine
Speed De is offline   Reply With Quote
Old 12-13-2003, 04:34 PM   #25
InitialD's Avatar
Ummm, if I were you, I would replace it because would not know how loose the rubber shield is. What engine is this? If it's a Nova based engine, the front bearings are easily replacable. Was there a thin shim before the engine brass collet?
A tip to protect the rubber seals is NOT to put thin 0.1 mm shims. Use 0.5 mm thicker shims as this would be easier on the bearing rubber shield. If it's a Centax clutch, mind the end float though and make necessary spacing adjustments after using thicker shims.
Old 12-13-2003, 06:28 PM   #26
Again.. very good tip here by Mr D....
If possible I even use 2x 0.5 shims(as long as the OD of the shim doesnt touch the outer ballraced housing of bearing).
With doing this, I only use a single shim in front of centax(clutchbell).
Trully, I got this tip from friend in local track which is working very fine to protect front bearing also.
GoldFinger is offline   Reply With Quote
Old 12-13-2003, 06:54 PM   #27
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: Re: Re: A quick check on your engine bearing.
your cut and paste job done very well EVO !
Manticore is offline   Reply With Quote
Old 12-13-2003, 08:53 PM   #28
InitialD's Avatar
I actually got that tip from mytsn and also later on Dino from STS mentioned about that same tip !
Old 12-13-2003, 09:55 PM   #29
EVOLUTION's Avatar
Default Re: Re: Re: Re: A quick check on your engine bearing.
Don't minimize my great effort !
Old 12-14-2003, 01:27 AM   #30
Manticore's Avatar
Default Re: Re: Re: Re: Re: A quick check on your engine bearing.
i said you did a good job rather then cut and paste someone else's idea ! you punk !
Engine Bearing issue rcfoolz Onroad Nitro Engine Zone 2 04-16-2007 05:57 PM
Engine Bearing Puller Land-Chaser Australia Wanted to Buy 1 05-27-2006 10:09 PM
Quick Can a ceramic Thrust bearing be used in a centax 2 TRFTIM Nitro On-Road 1 04-19-2006 11:56 AM
Bearing engine Dulac Onroad Nitro Engine Zone 3 12-20-2005 12:49 PM
A quick check on your engine bearing dino.tw Onroad Nitro Engine Zone 0 12-15-2003 02:12 AM
