Wheels locking up on Ntc3
Check the bearings at each hub. Take the drive shaft out and see if it is at one end or the other. There are many bearings in the drive train.... start there. Did something work it's way to one of the diffs. Did the one way bearing go out in the two speed.
Enough to start with?
The two speed is the only connection between the two ends... look there
Wheels locking up
Pull the diff cases out one at a time, and see if the gears are stripped.
