Old 04-10-2009, 05:56 PM   #1
Default Wheels locking up on Ntc3
Today my wheels began to lock up while i was running it and its hard to rotate my tires what can this be?
Hpi vorza
e-revo bl
slash 4x4
salabarria is offline   Reply With Quote
Old 04-10-2009, 10:29 PM   #2
Any suggestions to what this is?
Hpi vorza
e-revo bl
slash 4x4
Old 04-10-2009, 10:39 PM   #3
Zootcapri's Avatar
Check the bearings at each hub. Take the drive shaft out and see if it is at one end or the other. There are many bearings in the drive train.... start there. Did something work it's way to one of the diffs. Did the one way bearing go out in the two speed.
Enough to start with?
Zootcapri is offline   Reply With Quote
Old 04-10-2009, 10:52 PM   #4
Unhappy
oo ok well right now all four tires are hard to rotate whens its off
Hpi vorza
e-revo bl
slash 4x4
Old 04-11-2009, 09:43 AM   #5
Zootcapri's Avatar
The two speed is the only connection between the two ends... look there
Old 04-11-2009, 11:33 AM   #6
Trader Rating: 18 (100%+)
The NTC3 are famous for the gears in the diffs going out. If this happens at either the front or the rear, the wheels will lock up. The gears are plastic/composite material, and are really not very strong.
Pull the diff cases out one at a time, and see if the gears are stripped.
[COLOR="Red"][FONT="Comic Sans MS"][/FONT][/COLOR]BRC358http://www.kamikazercracing.com
nearest barstool
brc358 is offline   Reply With Quote
Old 04-11-2009, 11:40 AM   #7
ooo alright i will will this is my first problem with the ntc3 after 2 years of running it
Hpi vorza
e-revo bl
slash 4x4
brushless pan car w/ all the hop-ups jlev21 R/C Items: For Sale/Trade 19 01-23-2005 09:50 PM
