Old 04-01-2009, 02:50 PM   #1
Default Pro's i need help/info with picco
I bought a picco red dot evo3 and i have a Max power pipe on it, No bottom end, but the top end is impressive, Been told and after doing some search's found out that i have to get the 2607 pipe, is there any replacement for it? because it out of stock everywhere!! OFNA Picco 1/10 pipe would replace the 2607? or is it the same pipe? I am so confused with it
SmokinAce is offline   Reply With Quote
Old 04-01-2009, 03:33 PM   #2
Their are several pipes that will work with it, i would go with either the 2607, or the 2617!
Jeremy Cupps
Sponsors are
Mugen Seiki, NovaRossi Engines, Enneti Tires, Byrons racing fuel, Airtronics, XceedRC, Mikes HobbyShop Porter Texas, Global Hobby Distributors, Avid Bearings, Paint by Smiley, and my wallet!
J-MAN is offline   Reply With Quote
Old 04-01-2009, 04:16 PM   #3
mike jones's Avatar
The Ofna pipe is the same picco 2607 pipe but instead it has ofna on the side. I run the evo3 .12 motor and I run it with either pipe;they all came from Picco, and make sure to run the bottom end a little rich.
hopefully this helps
SHEPHERD MICRO RACING, CEFX, TEAM C, CONTRAST, PICCO, KO PROPO, NOVAROSSI, BYRON ORIGINALS FUEL, JACO, DCM HOBBIES, JGO PAINTZ
mike jones is offline   Reply With Quote
Old 04-01-2009, 07:53 PM   #4
I asked pretty much the same question here and got some good feedback... http://www.rctech.net/forum/exclusiv...-12-a-129.html
gladcow is offline   Reply With Quote
Old 04-02-2009, 07:40 PM   #5
japtj2000's Avatar
Trader Rating: 25 (100%+)
I am using this engine with a Skyline VR12 plus and Short Novarrosi conical header and the engine is a rocket with a very good bootom and top end. I am very happy with this combination.
I hope this help you
japtj2000 is offline   Reply With Quote
Old 04-03-2009, 07:56 AM   #6
SERPENT CURACAO's Avatar
Send a message via MSN to SERPENT CURACAO
I used it with the RB pipe 2604 and that thing is a rocket
i normaly use picco engine with their picco pipe like the 2607 or the 2617 from picco or mega or IDM
IGT8
NOVAROSSI ENGINES
MAXY'S FUEL
MAXY'S MODIFIED ENGINE
SERPENT CURACAO is offline   Reply With Quote
