Conrod and piston interchangable from nova to rossi pixi
Is the conrod and piston interchangable from nova to rossi pixi? Please help, broke my piston and my friend has a nova mega .12 thats modded. Will the conrod and piston fit?
Didn't you just say that you got it running awesome after Dennis said you could take all the shims out??
yeah it was running great, i shut it off and later when i tried to run it it made a funny noise on the starter box. I took it apart and a chip was taken out of the piston. So will the conrod and piston fit from another nova based motor?
The Rossi is not a Nova Rossi based motor. Two different companies
so will it fit?
what about just the piston?
No.
why not? what piston will besides stock?
I don't know the sizes of a Rossi/Pixi, but to give you an idea between all Nova engines everything is interchangeable, except conrod from the Mugen MT12, because it is longer than the rest that are short rods.
What you have to do is measure the lenght of the Rossi conrod from center to center and compare with the Nova conrod, then you have to check the diameter of the piston pin and cranck pin and compare, and last if the piston dia. is the same.
Another example is that no parts are interchangeable between Picco based engines and Novas, except maybe the button head.
Hope this helps
AFM
Hope this helps
AFM
Re: Conrod and piston interchangable from nova to rossi pixi
If your friend has a moded nova motor, why not just run that one the way it is?
As far as taking the shims out,DOOOOOOOHHH!!!!!!!!!!!
Dont you run 40% anyway? You should have added a shim or two instead!
See ya Sunday at O.T.H.
head clerance has and had nothing to do with his failure in any way.
unfortunatly the parts are not interchangable. however if you resize the big end of an MT long rod then you can use a novarossi piston if you can find one to fit properly. I have done this however I would not recommend it unless you have the proper tools to do it accuratly. the stack height is very close but u must use both together and resize the big end to fit the crank.
personally I would recommend a new piston and sleeve assy.
breakage
Hey motor man I found out how he broke the piston, he took the motor apart and I`m thinking he turned the p/s combo 180%
and the piston skirt hit the crank! DOOOOOHHHHHHH!!!!
well, my friends motor won't work. I don't know if i can run. I have a brand new ofna hyper 7 8pt. to trade anyone with an engine.
