Old 03-28-2009, 05:39 PM   #1
Default witch one is better from picco
witch is the better onroad racing engine the JLtuned #51128 or theJLR.12red dot onroad #51124.Has anyone used both these engines any input would be appreciated
truggy77 is offline   Reply With Quote
Old 03-28-2009, 05:50 PM   #2
Serpent-Dan's Avatar
Trader Rating: 16 (100%+)
They are almost the same engine the tuned version has a matched piston and sleeve you can't go wrong with either one and of course the tuned cost more than the other.
Inf1nity CM Beat1 Racing
Serpent-Dan is offline   Reply With Quote
Old 03-28-2009, 06:35 PM   #3
aussies1129's Avatar
Trader Rating: 74 (100%+)
I have used the jlr evo2 then the jlr evo3 and now the edo modified evo3 which is the tune version and the tune is a more pwerful smoother running engine, holds idle very well, but I think they are discontinuing the tune as alot of shops are not carrying it?maybe because they are bringing out the evo4 which I read in a thread somewhere? but if you had a choice just get the tune version and make sure you use picco plugs like the P6TH. I am sure kamikaze have these in stock if your in the US or some hobby shops in Hong Kong.
goodluck with it.
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 03-29-2009, 11:10 AM   #4
thanks for the help guys
