Conrod in D5 interchangeable with the s5 or s3??
Anyone know if the STS d5's conrod is the same as the ones in the ns12s3 or ns12s5? Thanks.
G
G
Re: Conrod in D5 interchangeable with the s5 or s3??
G
G
Re: Re: Conrod in D5 interchangeable with the s5 or s3??
Originally posted by eddiethefish
Yeah, I encourage you to replace the D5 conrod with the NS conrod. It's been proven that it's interchangeable, and it will not break in half when reving it fast. Right? DATA?
I highly recommend you stop leave your comment until you return my receiver.
Best Regards
Re: Re: Re: Conrod in D5 interchangeable with the s5 or s3??
Originally posted by rdlken
Etf:
Best Regards
Etf:
Best Regards
Etf:
Best Regards
Etf:
Best Regards
wrist pin....that's something that you don't need to change right? Sorry I've never changed anything inside of an engine before. I guess what I'm trying to say is - the wrist pin is reusable right? I'm planning on ordering some novarossi conrods both for my novamax and my sts d5.
G
G
it could be reused just have to check it for wear..but i highly recommend putting a new in..i mean they are only a few bucks and could save plenty of money..
Eddie,are you talking about the Dragon 5pt by STS?
Use its original con-rod to break-in engine. Then, replace it with Novarossi con-rod before running. Voila! vrooooooooooooommm...
Yes, the one and the only one STS 5-port Dragon...
the original conrod on my D5 has gone thru 1 gallow of fuel (including run in) and there is no obvious sign of wear. I replaced it when I did "special treatment" to the D5.
Originally posted by EVOLUTION
I think I have to message you to find out what kind of special work you've done MR TOM?
Yeah after talking to Dino from STS, apparently teh conrods in the Dragon series are updated and it's recommended to replace the rod after break in....but it's good that it's interchangeable with teh novarossi's....
G
G
NS12S5 con rod
Anyone know where I can purchase this S5 con rod in US? Thanks.
